Monitor screen is black—computer turns on by itself.
earguy
I am working on a desktop eMachine ET1831 w?Windows 7 Home Premium SP1.
I serviced this computer last week and removed a fairly large amount of malware. All seemed well.
The owner called me today to say that his computer hasn't been working for a few days now. When I power on the computer there is nothing, no beeps and nothing on the monitor. I hold down on the power button to shut it off, then I unplug the power cord, hold in on the power button for a few seconds and then, when I reinsert the power cord, the computer powers on by itself without out pushing the start button. I installed a new PSU and the computer starts normally, but still nothing shows up on the monitor.
I removed the RAM chips and inserted them one at a time, but nothing. However, the computer started to turn on again by merely plugging the power cord in. After a couple of shut downs, the unit starting turning on as normal, using the start button.
I have tried three other monitors that I know work as I use them daily but the screen is still black.
Ideas?
Thanks
Short on the actual power switch?. Have you tried removing the power switch from the motherboard, and see if it still does it?.
If it did, I would lean towards possible mobo fault.
I haven't removed the switch yet. That's a good Idea and I will do it. Thanks. Any ideas on the black screen?
Seeings how I think the problem with the blank screen is the on-board graphics port, if I install a graphics card, will the computer default to the card or do I have to configure it in BIOS?
I removed the switch and the computer did not turn on when plugging the cord into the back of it. However, it is intermittent.
Sounds like a dead motherboard to me. Why waste time on it? It has no video and power issues even after replacement of the PSU. I assume that you have stripped it down to the bear essentials? No drives. Only memory, video and a KB. If you can't get any further then that pronounce it dead and move on.
I have stripped it down as you've suggested. I will take your advice and pronounce it dead. Thank you.
Just to note....
Some desktops have a bios setting for power on after power loss. If set, it will kick on anytime power is applied to the machine, meaning plugging in the power cord.
When I delivered the unit to my customer last week, all was well. The monitor flashed yesterday for a moment before going and remaining black. I hadn't thought about this until just now but, would removing the CMOS battery for a BIOS reset possibly help this situation? Ninecomputers suggests a dead mobo and I think he is correct. I really am not wanting to tell this poor guy he needs another computer.
