T
The Tech Professor
Guest
Hello everyone,
Some more cool tools that I have on my USB Flash Drive. #1 & #2 update automatically. I just love Ketarin in Tech Tools. Hope this may help someone.
1) Tech Tools 3.0: Tech Tools has been extremely useful to me! Imagine having a bunch of great, free repair tools that you can update automatically to the most recent version!
Tech Tools is for techs and people who work on computers everyday, and need updated programs to keep with them on their usb key. Tech Tools uses Ketarin, which is an application downloader that checks to see if an application has been updated and downloads it if so. The genius in this tool is that we don’t have to have you download all these tools at one time from our website, you’re going to be downloading each file individually from the app’s website. This helps with our bandwidth costs and some authors of the applications, while freeware, wanted the only download of their software to be at their own sites.
2) LiberKey 5.7: A selection of great portable apps with automatic online updates. You gotta check this one out!
LiberKey is a collection of portable apps in a variety of categories that can be run on your local PC or from any portable media. Take these important apps with you and use on any computer. LiberKey is a complete application platform for local or portable use. It allows you to manage your applications quickly and without skill. Installation of an application from LiberKey catalog is done with 2 clicks but you can easily add any other application. After LiberKey 5.7 installation, the user has the choice to install Ultimate, Standard or Basic suites (so always updated) or to define its own suite with the online catalog.
3) CheckDisk: This tool will save you a lot of time! CheckDisk automates the Windows chkdsk.exe command line tool to run until no bad sectors, lost clusters, cross-linked files, or directory errors are found.
How would you like coming back to a system after running chkdsk.exe and still having file system errors? It can get irritating for the 20 minutes to several hours it takes chkdsk.exe to run, to have to check in on it and restart chkdsk manually 3-5 times or more. CheckDisk will use chkdsk.exe to scan the partitions as many times as it takes until chkdsk.exe reports that no errors are found, so the only user interaction required is to start the process.
Ultimately, this is a technician’s tool. It’s great for those of us running chkdsk.exe from a “Tech Bench” computer or bootable WinPE based CD, where you don’t *need* to scan your OS partition.
…but it can be quite useful for others. Anyone with multiple partitions and hard drives will find it useful for maintenance on all of their non-OS partitions, and in the event their OS partition needs repair, you can use it to schedule autochk.exe to run on the next startup.
4) ClamXav 2 and FlashbackChecker: I have not had to use either of these tools yet but I have them on my flash drive just in case I have to work on an Apple system (malicious website code can exploit a vulnerability in Java runtime).
ClamXav is a free virus scanner for Mac OS X. It uses the very popular ClamAV open source antivirus engine as a back end and has the ability to detect both Windows and Mac threats. ClamXav can be setup up as passive or active: scan only the files you tell it to or your entire hard drive, whichever you prefer; you can also choose to activate Sentry to monitor your hard drive and scan new files as they arrive.
FlashbackChecker checks and reports the presence of Flashback malware, it does not remove it!
5) Memtest86+: I can’t tell you how many times I have tested and diagnosed bad memory using this gem of a tool. Memtest86 on your flash drive is simply a must!
Memtest86 is a thorough, stand alone memory test for x86 architecture computers. BIOS based memory tests are a quick, cursory check and often miss many of the failures that are detected by Memtest86.
Best wishes,
The Tech Professor
Best wishes,
The Tech Professor
