Mike McCall
- Silverton, Oregon
I got to playing with my firewall (Untangle) in an attempt to tighten the network down and learn more about Untangle & firewalls in general. Right away I learned that properly tweaking one's firewall takes time and research. Fortunately I've learned enough that I only broke a couple of things which were easily fixed.
Once I got PIA setup under Tunnel VPN Netflix and Amazon Prime Video immediately broke. They don't allow VPN connections since they can't track everything you watch. Since I use a Roku for streaming I just needed to set up a rule to allow traffic to/from that internal ip address to bypass the VPN and the problem was solved, leaving all other traffic on the VPN.
I had previously blocked foreign countries such as China, Russia, etc., and started going through the Web Filter categories. Lots of thing I could block in there, many having to do with advertising, but that causes problems. It took me a few days to learn why I shouldn't block domains with no content. During that time I learned a bit about how domains aren't always used for http traffic. Apparently they are used extensively for both legitimate and illegitimate purposes and just blocking them all isn't a good idea.
What I'm having a hard time wrapping my head around is why I see so many sessions and why. I get that at least some domestic sessions might make sense, but sessions with foreign countries leaves me scratching my head.
The information I've been able to find simply doesn't explain (in terms my thick head can understand) why these connections are necessary or why they seem to be consistent. If I were to remove the Geoblocking the map would look much worse. So, my question is:
Why, when one connects to the Internet are so many sessions started, and why are they with foreign countries?
