Big Jim
- Derbyshire, UK
server is a Dell R720
I had warning pop up yesterday advising a drive pre-failure.
This drive is part of a RAID-1 array that contains both the host OS (Hyper V 2012) and all of the stored VMs.
I decided to upgrade to slightly larger SSDs (300GB > 480GB), from the current 15k SAS Drives.
The question is, how do I easily migrate the Host OS to the new Array ?
As I can't mix SAS/SATA and HDD/SSD in a raid array I can't simply pull the failing drive and let the Controller re-sync.
And a second question, is it bad practice to store the VMs on the same partition/drive as I have done here ?
