Both of those give me this error.Is this not it?: https://www.nvidia.com/Download/driverResults.aspx/176523/en-us/
That's the latest I can find from NVIDIA. An older one is here: https://www.nvidia.com/Download/driverResults.aspx/143231/en-us/
If you so happen to be using Dell hardware, see: https://www.dell.com/support/kbdoc/...x-1660-1660-ti-graphics-driver-doesn-t-update
Something not right with that system.
You need the standard driver package, just like it says. This should be it:Both of those give me this error.
Are you sure? You have to dig to find the page I linked to where you can select the "standard" driver. Almost every system uses DCH drivers nowadays so that's the default that will come up when you try to download the Nvidia 1660ti driver. If you're sure you're installing the standard driver and it still says you're not then either the link is bad on Nvidia's website or you've got another problem. Try an older driver from that list.I have tried exactly that one. It was the first one I attempted to install. It is a head scratcher for sure.
If that doesn't work then screw it. You don't NEED to use the Nvidia control panel. That's the main difference between the DCH and standard drivers. Fire up 7zip and extract the driver manually, then install it using the Device Manager.
Win 10 Home x64. I did try early on to use the GeForce Experience to locate the right driver. Everything seems to end up with a similar error message like I posted in the screenshot earlier. I delivered it back to the client today. He's only using it for an office pc, so it will meet his needs. No sense fighting this one any longer, wasn't worth the time & effort. Who knows, it may very well be a knock off/fake card.What version of Windows 10 are you installing? DCH drivers should be supported from v1803 and up.
