britechguy
- Staunton, VA
I may be getting old, but I don't think I've got the proverbial rose-colored glasses on regarding this. It seems to me that under Windows, up at least until Windows 7, and possibly in Windows 7, you could select folders with massive numbers of files and subfolders contained therein, choose to delete them, and *POOF*, they were gone. There was none of this "Discovering" stuff followed by a slow, item-by-item delete process with a progress bar. The entire structure was effectively, lopped off and every block marked as available.
My web search skill is not turning up anything that seems to work that way now. Using the SHIFT + Delete shortcut when you have a folder selected does bypass the Recycle Bin (which I also want) but it does not eliminate the crawling of the entire folder structure both prior to and during deleting.
In cases like this, I have no interest in knowing how many files are involved or how much space will be freed prior to the deletion.
Is there a "quick and dirty" delete function that can still be used? There's got to be, but if there is I haven't had need to use it in years, and now I do.
