JoelM
- Colorado, USA
I have a customer that is insistent that she use Outlook. I have installed the g-suite sync and everything works fine. I then add another account she has which is a Microsoft 365 exchange account. Everything seems to work fine. Emails sync. Calendars all work.
However if I try to add or edit a contact's email address or add a new contact with an email account I get the attached message.
"The operation failed. The messaging interfaces have returned an unknown error. If the problem persists, restart Outlook"
I have setup the same configuration on a cleanly installed machine with a fresh install of Outlook and get the same exact symptoms. Everything works perfect except an issue with editing email addresses of contacts or adding a new contact with an email address.
I have tried this with the contacts from both the G-Suite account and the Exchange account. Same results.
Help!
Help!
