Altster
- Indianapolis, Indiana, USA
All:
I made the following posting in the HP forums after reading all I could find there (HP Forums) regarding this problem. I thought I'd share this with all of you to see if anyone has any other ideas about the problem my customer is having.
-----begin
System Info:
Compaq Presario CQ56-219WM (Laptop)
s/n: {Personal Information Removed}
Windows 7 64-bit Home Premium
BIOS version F.15
BIOS vendor Insyde
Consistently getting Bios Error (90B) during warm / cold-startup of laptop computer (Black Screen Boot)
New fan/heatsink replaced 8/6/2013
Have tried Hard Reset - did not fix issue. I have not found a newer BIOS update available for this issue.
The computer is up-to-date (Windows updates). As mentioned above, the error only shows when the unit is either re-booted or first turned on. The fan is currently running quite fast.
I need to know from the experts here as to what could be causing this issue to continually "scare the customer / owner" of this computer AND if it could possibly be related to a main / system board of the laptop?
HP Support Assistant doesn't make any specific mention of this error other than on "1/24/2012" there was "Informational: Reducing Heat and Fan Noise by Clearing Air Vents." Next error was repeated today, 8/7/2013 AFTER heatsink / fan ass'y. was replaced.
Thanks for listening.
-----end
-----begin
System Info:
BIOS version F.15
BIOS vendor Insyde
-----end
