Problem connecting cables to Wi-Fi
No, they don't flip at all, just slide up and down. They slide up/down fairly easily, in my experience.
Yes, given space to work, and two hands, they are fairly simple, but trying to do it one-handed was quite a challenge. If I had been at the shop, I would have found a prop to hold up the LCD panel, lean-to style, but didn't have that luxury at the client's office. Larry, the brown cable in your picture is clearly NOT seated correctly - fully half of my attempts the other day ended up looking like that!
Yes, I noticed that. The picture was taken of the second Alienware recently received for a fan replacement and the customer advised last night that they are not going to proceed. The poor alignment is not my doing; other than taking the back panel off, I did nothing other than wait on the customer to approve the quote. Disconnecting and reconnecting the cables under the cover at the back is a nightmare, given the minimal spacing around the connectors.
All you have to do if you break one of those flips is use a shim to keep the cable pressed against the contacts on the motherboard. The plastic grip on the cable itself is ironically usually the perfect thickness for this. Cut off the plastic grip and use it as a shim and shove the cable into the connector. It works like a charm.
When I have to deal with this stupid WiFi cable connector, I often vent my frustration by fantasizing about going back in time and murdering the guy before he's able to invent it, thereby doing the world a great service.
I've found these aren't really strong enough. I use a metal pry tool, this one specifically:
Great.. Can you provide me a link? I will buy one and put it in my pile of pry tools
This is by far the best tool I've ever bought in my entire life. I have dozens of them scattered all around my house. I really don't know how I did my job before I owned this tool. Unfortunately you have to buy it as part of a kit and I found the other 3 pry tools it comes with to be absolutely useless.
I bought a nice set of metal spudgers for my son that have the colored metal grip on them. He uses them every day and loves them.
Ifixit has an antenna tool..
I got all excited, but looking at the thing, I think I need a video of it in action. I don't see how that would help at all with those finicky button connectors.
Edit: That is a DISCONNECTION tool. Helps to disconnect them safely. You're on your own for reconnecting them - haha.
I haven't used one yet but plan on buying one or maybe both as I have a really hard time installing those cables.
Haha, beat you Scott. I ordered one from Future Electronics because the price was better ($7.74+$8 S/H CAD). What do you mean by both? I assume there are tools for different sizes? Hope I ordered the most common size. I've lived without this tool for a long time so doesn't matter.
Yeah ifixit has 2 different sizes not sure how much of a size difference there is. The price at Future Electronics is much better, I may have to order one or 2 myself.
Can't say it's worth the money, no matter the price.
I disagree. Seeing as most modern laptops have WiFi cards that are permanently soldered to the motherboard, I want to make 100% sure that I don't damage those little connections. I've only done it once or twice, and thankfully only on WiFi cards that were easily replaceable, but it would p*ss me off beyond belief if I damaged the connections on a WiFi card that was permanently soldered to the motherboard. I almost damaged one couple of weeks ago on an expensive Alienware. I don't know how much that board would be to replace but I'm guessing it would cost $500+ plus my time and the aggravation of me having to replace it. I'll pay the $40 or whatever for the right tool in order to eliminate the possibility of this happening, thanks anyway.
It does nothing for me that I can't do with a pair of tweezers.
Or that I can do with the edge of one or two fingernails.
I don't love these connectors because they're so small, but dealing with them is not a monumental task. It's a snap (literally) for heaven's sake. Pull gently to remove, align reasonably well and push gently to seat. I can even feel the typical click when the two mate in my fingertip.
I use a hammer.
