Restarts After Shutdown
Dave 1973
Myrtle Beach, SC
I have a Dell desktop with Win 7 that restarts itself after shutdown. It happens whether using the power button or shutting down from the start button. If I start it in safe mode it will shut down normally and STAY shutdown.
What I have done to try to fix it:
Checked bios for power up after power failure. It is Off.
Turned off automatic startup in Startup and Recovery
Did a CLEAN boot with only MS services
Used Autoruns to disable non essential items
Turned OFF AV ( Norton)
Ran chkdsk /f
Lubricated on / off button
None of the above helped. Because it runs normally in safe mode it would seem
to indicate a software problem.
Does anyone have any ideas ?
Thanks in advance !! Dave
Ran chkdsk /f
Just for clarification so that people can answer your question more effectively, you are saying that when you shutdown, instead of shutting down the system restarts immediately? Is this happening 100% of the time you shutdown from regular windows or just sometimes?
Yes, the system restarts almost immediately ( about 15 sec after shutdown). It happens every time from normal Windows state. It is fine
when shutting down from safe mode.
Latest chipset drivers installed?
I'll try updating them
Bad capacitor somewhere?
It shuts down fine in Safe Mode and stays shut down. Seems to be a software issue ??? But I don't know...........
Thanks for the replies !!
Dave
Yes, the system restarts almost immediately ( about 15 sec after shutdown). It happens every time from normal Windows state. It is fine when shutting down from safe mode.
15 seconds after shutdown!? As in the system powers off then 15 seconds later it turns back on? Now that I have never seen before not with "Checked bios for power up after power failure. It is Off." off. This is an interesting one and only happens after a normal shut down hmmmm... before you shut down from normal mode, unplug everything from the computer aside from power, mouse, display cable, start shutdown, unplug mouse and display cable. Does it still come back on?
Also what happens if you take an elevated command prompt and issue shutdown /s /f
Thanks for your suggestions. I tried shutting down from an elevated command prompt and it did not help.
I tried a bare bones shut down with all the extra hardware disconnected and using a clean boot. It still powered on by itself.
I finally discovered the problem. I remembered that safe mode uses the VGA graphics so I rolled back the video driver and that fixed it !!
The video was an Intel I3 driver on the chip. Widows probably updated the driver recently because the PC was fine a week ago.
Thanks for all your help guys !!
Dave
Dave
Interesting, which model dell was it?
This is interesting. And weird.
What is the supposition here? That somehow the bad video driver was twisting the shutdown command into a restart command?
TBH this is an issue I don't think I'd ever have figured out! My bet was on "wake on lan" or something similar misbehaving.
Make sure they don't have some stupid driver updater program on the computer. Those damn things screw up a lot too and it might come back again if they run/install it.
I read this and it started me thinking about drivers:
https://blog.techinline.com/2018/09/18/windows-10-restarts-after-shutdown/
My only clue was it worked OK in Safe Mode. I tried to think of drivers that wouldn't load in Safe and thought of video.
I set Windows update to have let you know before downloading and installing. I told the customer not to install any updates related to Intel.
Wish Win 10 would give you the same option !!
