System: Samsung NP350V5C
Problem is that, for a few minutes there's power, but after a couple of minutes the system loses power. Power LED turns off.
I've tried to replace the power adapters and eliminating the battery. What works (for a few seconds/minutes) is to disconnect the power connect it again (the power LED turns on again). The longer you wait, the longer it holds the power. If you had to try to disconnect and connect the power within seconds from the last power off, it will only hold for seconds. It even does it in BIOS, so it's surely not OS related.
Also, not sure if this is Windows 10 related issue, but the battery charge data seems to be incorrect (i.e. 8% charge - 3 mins to full charge).
Problem only seems to be affecting the system when it's powered on. When it's off, it keeps on charging (LED remains on).
We haven't tried replacing DC jack yet, cause we don't think it's related to it.
For some extra information, last month we've replaced the screen on this laptop.
