jfm
- Montreal, Canada
The harder you're scratching your head, the harder the mobo is laughing at you
The harder you're scratching your head, the harder the mobo is laughing at you![]()
A FLIR One is only $240 USD. It's a smartphone add-on. If I did more component-level repairs I'd be bugging Santa for one of these.Do you have a thermal camera or a leaser guided thermal gun yourself? If yes, do you recommend any in particular?
It depends if it's a simple component or not. I can't recall the name (I am slowly teaching myself and learning about these circuits) but these chips have a gate, drain and source. They have three leads. Never mind, I cheated. MOSFET.
They are responsible for switching voltages, amplifying etc. On many TV sets Mosfets are responsible for no power. The circuits are similar in the sense of switch mode PSU then a DC to DC circuit.
The trouble is many of the Mosfets are so tiny, you need a schematic to know proper values as it might not be labelled.
After Mosfets are Tantalum Capacitors. Well, most caps really.
In basic circuit, Caps, Mosfets, Transistor and coils. The surface mount type are tiny, never tested them.
If you have a thermal camera or a laser guided thermal gun you can narrow down areas that overheat prior to shutdown to try and pinpoint quicker if it's a heat failure. (The reasoning behind this is failing electronics often have very low efficiency ratings, hence will generate more wasted energy/heat which can often trigger fail safes to prevent catastrophic failures.)
It's just a diode – 'fast switching' is its characteristic. I suspect it's just a SMD version of the ubiquitous 1N4148 and is there to prevent backflow to the battery ('BATT+'). PD1 performs a similar function on 'VIN'.... which is a LL-34 switching diode.
There isn't really an input or output – better to give the voltage on the cathode (the line end of the symbol) and anode.The voltage input on this diode is 15V and the output is 0.68V.
