sapphirescales
- At My Computer
I upgraded my main laptop from Windows 8.1 to 10 yesterday and I've noticed quite a few bugs. My 8.1 installation was smooth as butter. I've never had anything weird happen since I did a clean install over two years ago. But now on Windows 10 I've experienced the following issues:
1. Slower - Any time I try to do anything beyond basic web surfing (i.e. Photoshop), the system sputters and performs about as badly as a Core 2 Duo with Windows 7 trying to do the same thing.
2. "Pictures" folder refuses to open - I can open it manually by going to C:/Users/etc. but as soon as I try to use the shortcut, it fails. I have no idea why. It's pointed to the right folder, but it does nothing when you click on it. And it's throughout the system too. Whether I try to open it from "File Explorer," the tree menu on the left, or the shortcut in the start menu (which needs to be manually activated in the Settings), nothing happens when I click on it.
3. Microsoft Edge SUPER Slow & Won't Type Correctly - I'd rather use IE6 than this garbage. Even bringing up YouTube makes the CPU go to 100%. When you go to type something into the annoying "Where to Next?" box, the existing text just becomes highlighted and won't go away when you start typing. If I hit the backspace button, it closes Edge.
4. My trackpad no longer scrolls correctly at all times - It's okay most of the time. But with drop-down menu's, it's TERRIBLE! It simply doesn't work anymore. It could be a driver issue, but I don't think so seeing as it works with everything but drop-down menu's.
5. Cortana doesn't pick up my voice very well - My microphone works. But Cortana can't hear me properly. Although I've always had a hard time with voice recognition software, it's 2015. I expect better than Dragon Naturally Speaking from 1998.
6. I've tried the new Pictures app to view pictures (as a replacement for Windows Photo Viewer). It's dysfunctional. I can't even go from one picture to another in order when I open it. The order is mixed up. It's totally useless. And the pictures appear blurry. Come on Microsoft!
I'm going to hold on the way it is for a few weeks and see how it goes. If these are general bugs that Microsoft can fix, great. But I have the feeling it's because I did an OS upgrade rather than a clean install. It's 1998 all over again! If that's the case, then I'll certainly be busy. With all these people upgrading, a LOT of problems are going to crop up.
