SSD not recognized
johnrobert
Vancouver BC
I have a cheap Chinese KingDian SSD
When I try to install Windows 10 it does not show up, nor does it show up when I plug into computer with USB adapter
wondering if there's any other way to format it, it did work at first but I don't know what happened.
Not showing in device manager or disk management, Correct, but that is not uncommon had a USB drives do same when they were expensive a 64 gig I found a utility that saw it and format it.
Linux does not see it , nor Gparted when plugged into Windows it says device not recognized and does not show up in disk management
no data on it just waqnted to use it on an older laptop, its very rare that Windows does not see it during install.
This is the first SSD I have fail, nearly all SSD's are from China, but best to stick with known brands as there is little savings
Well, I could say all water is from Earth, but it depends who you get it from that matters. Same with SSD's. While it's true that you can get cheap ones, they have almost zero QC and often the machinery is not well maintained and shortcuts are made. You also get zero warranty.
You get what you pay for.
I've eyeballed these for non-critical items before, but the way I look at it; The price is just too narrow of a gap to warrant the price difference.
Granted, I'm dealing with RMAs on a bunch of other brands, including a Samsung 860 Pro, all with very low write counts. Some just right dead; The Lexar was just in the middle of use, now the drive reports "D NUL NUL NUL" repeated across surface of drive. Succeeds self tests and read tests; Instant fail on write...
At least the samsung went into this degraded mode where I can clone the drive at its last state. This is the best for client data, but I have not seen one where the full clone is actually able to succeed being put straight back in without a full reinstall.
Did we determine that the issue was the fact that it was a cheap drive? I have the same issue with a Western Digital my passport. Windows has some sort of driver issue for this one, but when I plug my other one in it works just fine. Could there still be an issue with his computer that it's not seeing it? Mine isnt a cheap drive and it's doing the same thing.
Does it work in other computers?
If you look at Amazon reviews, most of these SSD end up failing after a few months.
They are garbage and this is a rarity for me, but the day I use one of these is the day I'm no longer a tech. That's how low they are. Sorry. Some things just aren't good.
Not sure if you opened it up but the drive might be normal sata with a board and you could try the drive direct. I haven't opened one in a while but I know a few years ago many had the USB connector directly on the drive board. The board may well be shot.
Please don't take wrong way. Please don't cheap on your clients. You need to set yourself aside from the competition. A business prof at UND taught me:
Never compete based on price, because there will always be someone willing to go out of business quicker than you.
Not to say you shouldn't be thinking about price, but if you use price to set yourself apart, you will damage yourself and your brand. You will attract all sorts of garbage, including people who won't appreciate you being the cheapest and expect cheaper/faster/better. I mean, look at how well someone in our group does with pricing themselves at crazy point. Means it is doable.
It's like the joke of "Cheap, speed, or quality; Pick two. You will never get all three." - I think if you pick cheap, you will ALWAYS lose quality and speed.
Can you get away charging double? Sure. Half the customers, double the price. You make the same and have a bunch more free time, or you have more time to find more clients to pay more.
Granted, this does only work if you have a market to do it with.
THAT SAID, and back to topic; Obviously the components from Kingdian are coming out of some supplier for parts, but they too have done SOMETHING to come to the lower price. Are they using old controllers? Are they using cheap storage OR cast-off storage that other manufacturers won't accept the quality/rated MTBF? If you read reviews, lots of good, but start looking between lines. Lot of more knowledgable people have indicated they do take shortcuts for that lower cost, and other reviews do show premature death.
Do you want that for your client? Quickest way to make sure a customer doesn't come back in your door; Lose their data from choosing a bad drive. And I will tell you, other techs will bash the HECK out of you TO the customer for using Kingdian.
HP was AWFUL for zero-life drives for a while, and they did hurt their brand for it. They also used those awful Seagate drives with the label (Momentus Slim?) - I have 0 respect for HP to this day, even though I know they've started reversing. Big companies will save themselves $0.10 a unit by going with garbage drives, just to save themselves $100k per million units.
Set yourself aside from the competition. Be the one everyone goes to when others goof up. Don't brag. Don't put others down. But don't be afraid to showcase what you do. You'd be surprised at how much advertising your trusted brands will get you too.
Want cheaper? Pick a generation older SSD. MX500s are really not much more than Kingdians, and will save you sanity. Does saving a customer $5 make up for 2-10% of those same clients coming back in your door, blasting you for picking garbage for their system? And if $5 will close a deal for you, if someone is that tight of a penny pincher, is that a customer you want? (Answer: No)
