It could be me or it has been a while since I been schooled in the obvious of troubleshooting but I have a problem and hoping I can bounce it off some of you here to see if I am missing something...
Customer calls me and states the PC wont work anymore, he recalls having it on and seeing "triangles and squares" on his monitor, then it shut off a minute later.
I went to his home, he has it hooked into a surge protector, it is a systemax 3 years old in age. He has everything hooked up correctly he even has an external zip drive attached. When I turned the system on, nothing happened. I reattached all the cords to the surge protector and got nothing. With the PSU not making any noise, the fan not spinning he agreed to have me bring the system to the shop and take another look.
First thing I do is test the power supply with the tester and it claims everything is OK, and the system powered on including the exhaust fan and heat sink fan.
I went ahead and hooked everything back up, the system fired up but no signal on to the monitor and the monitor goes to sleep mode. I reset the defaults on the monitor to be safe and still got nothing.
I ran the system for a few minutes to see if anything was hot in an obvious way to indicate an overheated part, and also checked to see if anything was cold such as the CPU and heat sink area, they seemed fine.
Then with the aide of some troubleshooting charts I have had it seemed obvious the on board video might not be functioning. So I put in a video card hooked it up and still have the same results.
So now I am stumped but also question if I overlooked something obvious. I am not sure if I should replace the power supply, swap out a cable somewhere or look further into seeing if there is something with the motherboard. I did not notice any obvious swollen capacitors though.
Any guidance would be appreciated. Thanks!
