frase
- Melbourne, Australia
When I got there the system booted up there was no issue, the issue was a boot loop, so I though ok failed update.
Then I ran SFC than ran fine, then was about to run DISM when the error came up
"Page Fault In Non Paged Area."
Now due to my experience, I may be wrong though this generally points to a RAM module issue or sequence issues.
So I powered it off, Removed one Module and placed it into Slot A [2 x8GB] and left the other out.
It then completed an update, which I thought may have been the issue in the first place.
I then ran a stress test on the module for about five minutes under heavy load and was fine.
I then did the same for the other, fine then both and no issue.
Then I used both with the 1/3 configuration.
So that I think was that the modules were in the wrong slot locations, which I thought odd.
I did not have the time to run a MemTest+ as was onsite.
So after that I ran SFC and DISM, repaired any integrity and system health issues. I then powered down and it would not shut down, fans RGB etc stay on for infinity. So I had to hard shutdown via power button.
Checked all relative power saving settings switched off any that were on in -
- USB
- WIFI
- SLEEP
- PCI EXPRESS
Powered off system and still hung, no power down
-Removed GFX Drivers via DDU
-Installed new
Still power issue, so in the end I had to advise the client to Hold Shift+Power to force the shutdown as I could not figure out as to why.
I think it maybe an update issue, so am looking more into that. As it never did this before the update was installed, that caused this issue in combination to failing due to the RAM issue as well.
Has anyone came across this out there - is running
Win11 Pro [ unsure of exact version ]
Aurous Board & Aurous 3070Ti with Corsair RAM.
- USB
- WIFI
- SLEEP
- PCI EXPRESS
-Installed new
