Task scheduler not working how to fix?
Galdorf
Ontario, Canada
I am working on a customers machine that required a windows repair because of corrupt system files, every thing but task scheduler is working i have tried the following.
1. created a new account and used that accounts username-password did not work.
2. Removed task scheduler and reinstalled using xplite still does not work.
Anyone have any idea how to fix this, this is the first time i have seen a problem with task scheduler.
MCAFEE CLEANUP
December 30, 2009 09:41:09
INFO Cleanup will be scheduled and run.
INFO Product mpfpcu to be removed from system.
INFO Product mpfp to be removed from system.
INFO Product mps to be removed from system.
INFO Product shred to be removed from system.
INFO Product mpscu to be removed from system.
INFO Product mskcu to be removed from system.
INFO Product msk to be removed from system.
INFO Product emproxy to be removed from system.
INFO Product mas to be removed from system.
INFO Product fwdriver to be removed from system.
INFO Product hw to be removed from system.
INFO Product mbk to be removed from system.
INFO Product mcproxy to be removed from system.
INFO Product mhn to be removed from system.
INFO Product mqccu to be removed from system.
INFO Product mqc to be removed from system.
INFO Product shrd to be removed from system.
INFO Product nmc to be removed from system.
INFO Product redir to be removed from system.
INFO Product mna to be removed from system.
INFO Product mwl to be removed from system.
INFO Product msad to be removed from system.
INFO Product vs to be removed from system.
INFO Product msc to be removed from system.
INFO Product mcpr to be removed from system.
INFO Task Scheduler service started.
WINERR IPersistFile::Save() failed. Error: 0x80090016
FAIL Error while running cleanup using Task Scheduler.
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 2:54:00 PM ** ERROR **
The attempt to retrieve account information for the specified task failed; therefore, the task did not run. Either an error occurred, or no account information existed for the task.
The specific error is:
0x80090016: Keyset does not exist
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 2:59:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 3:04:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 3:09:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 3:14:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 3:19:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 3:24:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 3:29:00 PM ** ERROR **
"Task Scheduler Service"
Exited at 12/29/2009 3:32:21 PM
Started at 12/29/2009 3:33:05 PM
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 3:34:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 3:39:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 3:44:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 3:49:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 3:54:00 PM ** ERROR **
"Task Scheduler Service" 12/29/2009 3:57:07 PM ** Error **
An error has occurred that will negatively affect the operation of the service.
0x80070005: Access is denied.
Try using the Task page Browse button to locate the application.
Exited at 12/29/2009 3:57:25 PM
Started at 12/29/2009 4:00:53 PM
"McAfee Cleanup.job" (mccleanup.exe) 12/29/2009 4:05:16 PM ** ERROR **
Exited at 12/29/2009 4:19:42 PM
Started at 12/29/2009 4:20:14 PM
[ ***** Most recent entry is above this line ***** ]
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 1:04:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 1:09:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 1:14:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 1:19:00 PM ** ERROR **
Exited at 12/29/2009 1:21:54 PM
Started at 12/29/2009 1:22:41 PM
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 1:24:00 PM ** ERROR **
"McAfee Cleanup.job" (mccleanup.exe) 12/29/2009 1:25:31 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 1:29:00 PM ** ERROR **
"McAfee Cleanup.job" (mccleanup.exe) 12/29/2009 1:30:57 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 1:34:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 1:39:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 1:44:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 1:49:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 1:54:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 1:59:00 PM ** ERROR **
Exited at 12/29/2009 2:01:17 PM
Started at 12/29/2009 2:01:52 PM
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 2:04:00 PM ** ERROR **
"McAfee Cleanup.job" (mccleanup.exe) 12/29/2009 2:04:01 PM ** ERROR **
"McAfee Cleanup.job" (mccleanup.exe) 12/29/2009 2:05:38 PM ** ERROR **
Exited at 12/29/2009 2:06:40 PM
Started at 12/29/2009 2:07:18 PM
Exited at 12/29/2009 2:08:11 PM
Started at 12/29/2009 2:13:30 PM
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 2:14:00 PM ** ERROR **
"McAfee Cleanup.job" (mccleanup.exe) 12/29/2009 2:18:56 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 2:19:00 PM ** ERROR **
"McAfee Cleanup.job" (mccleanup.exe) 12/29/2009 2:19:23 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 2:24:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 2:29:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 2:34:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 2:39:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 2:44:00 PM ** ERROR **
"User_Feed_Synchronization-{7BABE9A6-4943-4A02-B6F2-4AC4637809C0}.job" (msfeedssync.exe) 12/29/2009 2:49:00 PM ** ERROR **
hmm even though this fix was for 2k it seems to work:
1. Double-click My Computer, and then click Folder Options on the Tools menu.
2. On the View tab, click to select Show hidden files and folders, and then click OK.
3. Delete all of the files in the "C:\Documents and Settings\All Users\Application Data\Microsoft\Crypto\RSA\S-1-5-18" folder.
4. Restart your computer, and then run the task.
