phaZed
- Richmond, VA
Hello Everyone!
I thought it would be nice to share the steps I take when disassembling a laptop. This is mostly in response to the thread "Laptop Screw Symbol Tricks" http://www.technibble.com/forums/showthread.php?t=18494. I have tried different screw management techniques and nothing has been as cheap, fast, and perfect as this. I have never had extra screws or mix-ups during re-assembly. In this example this HP laptop has a broken DC power jack which will require the laptop to be taken apart completely.
First, you will need a plain sheet of 8.5 x 11 paper, a towel (microfiber prefered, or other soft top as not to scratch laptop lid), a pen, screwdriver, and a small Awe.
Next, we need to remove all of the covers and hardware from the bottom of the laptop. This will expose all screws that may be hidden. Be sure to place all of your parts into or on an anti-static bag of some sort.
Now we can see all of the screws that need to be removed. Start by taking your blank piece of paper and drawing a rough outline of the bottom of the laptop. I like to draw basic features such as the battery bay, cover locations, as to give a orientation reference as we move along.
Now punch holes into the paper where you have screws drawn. It is important to punch the holes with an Awe or something similar. Not punching a small hole, and then inserting the screw will rip the paper, and the paper will not hold the screws tightly.. which means you will probably lose one. To make punching real easy: place the rough outline paper on a towel, then punch. We don't need any bloody fingers.
Next, remove all of the screws and punch them into the oppropriate spots on the paper.
Here, you can see the paper is upside down, and all of the screws are held securely in place.
Now we flip the laptop over, right-side-up, and remove the keyboard and keyboard trim ring to reveal some more screws. So I draw another simple sketch and punch some more holes. I also punch holes for the LCD hinge screws as well.
Now we can remove the top cover of the laptop to reveal the motherboard and some more cabling. Now is a good time to draw a diagram of the motherboard, punch, and remove and place the screws in the paper.
Now that the motherboard is removed, I can replace the DC power jack. In this case the DC power jack has a set of wires that connects to the motherboard, rather than a DC jack that is soldered directly to the PCB board. Yay!
Now it is easy to reassemble the laptop and place the screws into the correct positions... another job well done! It works!
I hope this helps some of you out there using pill bottles and other methods that "lump" together a bunch of screws that may be slightly longer/shorter or fat/skinny. If your repairs didn't go as planned, you still have your paper so you can disassemble the laptop again if needed.
Sincerely,
Sincerely,
