jbartlett323
- Spring Hill, KS
Hi Everybody!
Got a question on my own in-house server. I keep losing time every Sunday and cant figure out why...
It is a Server 08 R2 running on an AMD 1050T w/ 8GB RAM and 6TB of space in RAID 5. Unless its part of the problem (and you can prove it) this thread is not about the merits of server boxes...
This box is our DHCP, DNS, AD, Hyper-V, Backup, File Server, Intranet site, and everything else i can throw at it. Its only host to 2 users and 3 service accounts so i'm not overly worried about loading it down with everything and the kitchen sink as i could rebuild in less than a day.
Now on to the problem:
NTP will not stay sync'd! For some reason every Sunday at ~12am it just decides not to use any time data its sent and soon thereafter all workstation of course start losing time.
Things i have tried:
Googled,
Googled,
Googled,
Binged,
Googled,
Reset all settings (i'm using GP for config btw)
changed NTP provider to NIST.NTP.GOV
changed back
reset all settings again
enabled w32tm debugging (which is how i found that its happening on sunday)
Forwarded 123 through my firewall
Googled,
changed settings for update interval, etc.
changed the GP i was using to apply the settings
changed back when gpresult showed it wasn't applying.
and prolly a couple of other things i forgot i tried.
I figure it has to be a problem with my settings, but which i dont know. hoping someone has seen similar and can point me in the right direction. I know i could just set a batch file to do a w32tm /resync every monday morning, but i like fixing things not working around them...
here is a screeny of my settings, i can also provide debug logs and other settings if needed!
Googled,
Googled,
Googled,
Binged,
Googled,
changed back
Googled,
