ComputerDave
- Owensboro, Kentucky
Intel has its own tool. OCCT is all over the place and has proven to be unreliable. What are you guys using to test AMD CPUs?
We have a gaming rig that I highly suspect has a faulty AMD CPU. I would just like to have a smoking gun instead of guessing.Sorry I don’t have any advice, but I have a question: why are you testing CPUs? I don’t do much hardware troubleshooting these days so maybe that’s why I don’t do it. Are you building machines? Or is the test part of broader troubleshooting?
Thank you for that. I will check out the Prime95 and see what happens.Put it in the oven at 200 Degrees Celsius for 5 minutes.
Have you tried Prime95, works for me on Intel & AMD.
Here is a guide I found may be helpfull, not on Prime95 though in general.
Yes, this is a very valid point. That probably would be best. The only drawback is I might get stuck with some CPU's that, by the time the opportunity arrives for me to move those, I might have to take a loss.I've gotten to a point where I keep a few spare CPU's in the shop (or I'll order one of whichever generation/Brand needed). If I think a CPU is the problem - I plop a new one in, assuming I've exhausted everything else.
Have you received the results you felt were accurate using the Intel tool, even with AMD?The Intel tool works on anything.
A CPU is a CPU... it either runs the operations and returns the expected result or it doesn't.Have you received the results you felt were accurate using the Intel tool, even with AMD?
