For many years, I've used Ubiquitis "airMax" and "airFiber" products....for creating point to points, and point to multi point connections. Such as a "campus" of a business...or campgrounds, marinas, even providing internet to a school on an island 6 miles offshore from a Comcast connection on mainland.
airMax are the smaller radios.....airFiber are the larger radios, more bandwidth, greater distances.
Ubiquiti used to have a great guide that I'd frequently post in threads like this, it was very recently removed since they're doing a complete revamp of their UISP products....with the new "Wave" line.
Deploy scalable fixed wireless networks with thoughtfully designed hardware and streamlined management.
uisp.com
airMax will not meet your bandwidth needs...
uisp.com
airFiber can....
uisp.com
You manage your clients airMax and airFiber radios in a dashboard/portal called UNMS, which you can use at UI.com for free.
However, let's look at a relatively newer product introduced in the Unifi lineup, called the "Building to building bridge"...
A 60 GHz wireless point-to-point bridge with 10G SFP+ uplink for maximum performance.
store.ui.com
You manage these in your Unifi controller for the site...which I love, since I usually have Unifi switches and Unifi APs there also...and sometimes their Unifi gateways since they've been getting good lately.
You purchase these in a kit...they come pre-paired...you just need to mount, power, and aim 'em!
The only question I have....is...what's your actual distance...accurately? Because..at 1/2 a km....you are at the spec'd max of 500 meters...aka 1640 feet. Realize the "up to 6.6 gigs of throughput" is of course at much closer range and ideal conditions. At max distance....the actual throughput can likely still meet your needs...depending on things like....if line of site, other conditions, other interference, how well they're aimed, etc.
With "line of site"...for point to point radios and their links, you have to consider "the Fresnel zone". Picture an elliptical shaped beam between the two radios...what its diameter might be for the specific radios and their setup...and ensure you have a clear path for that beam. Might be just 15', might be 25', might be 30'.
