DCGPX
- Bradford, United kingdom
Getting Dropbox 404's on the links? Are they down?
Uh oh. I'm getting a 500 error at pxe-dust.com right now.![]()
Hello
Just tried to download sudo wget http://www.pxe-dust.com/downloads/core/pdinstaller.tar.gz -O /opt/pdinstaller.tar.gz
and i'm getting
HTTP request sent, awaiting response... 404 Not Found
2013-01-22 14:54:32 ERROR 404: Not Found.
Any tips.
Paul
Finally got the system working, (just cloning the drive) would it be possible to somehow add custom iso which are not listed under the install guide. Sorry if I've missed obvious.
Paul
May I ask what kind of ISO or program you are adding? I may add it to the I staller. Mind you this is a work in progress, and there will me more added in the future.
Uhm, please pardon my dumbness.
I've had two issues:
1. The tutorial in the OP is a 404 for me, so I grabbed it from the main site. It is only chapters 1-3.
2. Upon installing FOG, my install hung for ~20 minutes after the "notify" step, so I rebooted. I am able to log into it from another machine on the network, but I haven't gotten any further than that. Really hoping I can add isos somehow.
I am installing via the VM method.
Actually, and IDK if this is correct, but I got everything working a treat with FOG.
I realize that the intention of the pxe environment isnt' to load ISO's, but I need it to load ISO's, so I made that work. Hiren/KAV/BitDefender/HDD Regen/TRK/and more, all running a treat.
Thanks so much!
When I start the server,it tells me it needs to update, but I can't seem to readily locate the update syntax.
This forum post was a lifesaver.
KAV won't work unfortunately. Has to do with the version of Linux they used for the live disk.
Soon there will be a menu option for custom ISO's and a menu file you can customize to boot said iso images.
To do update to the server software.
Sudo apt-get update
Sudo apt-get upgrade
