4ycr
- West Lothian, Scotland
Quick question, you say to use a 64 bit but I have a couple of old P4 systems, can they be used to test things out?
Dbdawn thanks for the input! That is a great menu! In this guide I will be using WinPE to start the Windows installs from a network share. Its not as good as WDS, but it works rather well.
Some of the programs I have added so far work flawlessly, other could use improvement, such as booting WinPE and the like using chainloader.32 instead of using memdisk to load the iso. Which I don't like doing, but I have not figure out how to to the latter with the many different version of WinPE, WinRE and M$ ERD disks. I also can't get that damn NT Password reset to boot properly yet! Maybe its the newer version I have I dunno.
All WDS does is load a WINPE and automatically connect to a network share. I think you can easily do this without WDS.
I am using an older version of Memtest, NT Password Reset and Parted Magic as the newer version gave me some trouble.
just trying to install fog,
Can you clarify step 3 page 2.
open winscp ( on another networked pc???)
I can ping the ubuntu server ip * .*.*65 but win scp will not connect from another windows pc ?? even with username and password just get connection refused??
ta
Not sure if this is your issue, but use spacebar to select packages, if you hit enter it will just continue to the next screen.I am not sure that open ssh installed correctly, just starting over again.
Last time when it got to the options package it seemed to jump striaght on to next part when I intended to select the ssh package. Will watch what happens at that point again this time
Thanks again.
That was the exact issue. !
Not reading the screen before hitting return !!
Got it right second time.
Now past winSCP and installing fog and setting up mysql server.
Thanks for this! I've been meaning to set up a PXE server, but have been putting it off as I wasn't looking forward to the massive documentation gathering exercise. Your guide coming from the perspective of a PC tech is a great time saver!
possibly a stupid question, but can I run Ubuntu Server as a VM inside of XP and achieve the same result?
