i Haven't found the resolution setting yet. It's not where the bit rate setting is.Drop resolution
If you don't have adequate tube not gonna be able to do much
Drop resolution and bit rate
thanks. the on prem viewing through the web interface is fine. I might even up the bit rate again. I think i'll give the remote viewing a miss for now.On Protect...you change the Bitrate, and the FPS.
Done in properties of each camera, under General section.
Unless you have a strong internet connection.....viewing from the cloud while on prem is challenging. For viewing on prem, set the smart phone viewing app to hit the NVR on the local IP...runs smooth as butter with all settings on high.
tried various things, upped the sensitivity. it's just plain missing things. a person will walk from right to left and it gets captured. do it again, nothing. it's almost like there's something preventing it from capturing for so many seconds after the last capture. it also stops recording in the middle of the event, like there are people doing stuff and it just stops.Adjust zones...
And adjust the sensitivity, as well as time to trigger an event, time before, time after.
always record? not motion events? So your cameras are always recording but it still registers 'events'? I might be trying that out today.I dunno...I haven't noticed that issue with ours. I have 8 cameras on our old beta CKGen2Plus.
I just looked at the events....and the top 3 include me walking briskly down the hall to go piss...and then 20 seconds later me walking back up the hall. The camera is basically just outside my office door..facing down the long hall.
I have used ours to look at events and never felt it missed something..always seems to catch people walking into a room and back out.
Mine cams are set to *Always Record, and other 3 settings are 1s, 2s and 2s in that order.
how is that working out storage-wise?
Ok. So I guess the measure is how far back the timeline goes which is what we care about I suppose. I'll be watching that over the next few weeks.Works out fine....they record much like todays new server disaster recovery/nearly continuous backup services to....only the changed bits, not everything. Events makes note from the recordings. So it's efficient in space consumption.
I just went to check to see how much storage is used...but noticed they removed that in newer versions...I can't see a bar of how much of the storage is used. Anyways, with our 8 cams...I have it at 30 days and I don't recall it being very full in the past.
I don't know what that means.Remember all these are pixel based, motion detection will suck
Do things like line crossing if able
We can't read number plates but he's not so worried about that. Is there a way to improve resolution on a single camera so we can read number plates and logos on trucks etc?.
.I could tell you if the license plate was mounted with hex screws or philips screws..the image was THAT zoomed in! The cameras were about $4k a piece!
I've just been reviewing the night-time video and it's just sensational! I was able to see the boss come back to shop well after dark, wander around doing stuff then leave again. He was clearly recognisable without any room lights on.You'll often see me mention we use Unifi for indoor use and "light outdoor use"...and that they are not "license plate cams".
For plates..it's about placement (put cameras where cars have to pass..covering coming, and going...placed low)...if placement can't work, it's about a lot of money spent on cameras with higher end optics. Similar with faces...place low, not up high where all you record is the tops of heads.
For adjustments..eh, not too much. Denoise a little bit, because that can vary based on the environment each camera might be in.
yes, we need one of those squeaky computers on the telly that can make something out of nothing.Of course! You just need the software that is used on every police show I've ever watched on TV.
Boss: "Can you enhance that?"
Unreasonably skilled IT person: "Let me try something...." Types rapidly.
**magic software does it's thing in seconds**
Boss: "837.....We got a partial! Keep working!"
Unreasonably skilled IT person: "Ok - I'll let you know when I have something"
Boss: "...and run facial recognition on that guy with the baseball hat looking at his feet"
Unreasonably skilled IT person: "Will do! There's a reflection of him in the shop window, I can work with that!"
