NETWizz
Here is the background:
Years ago I had an nForce 4 with 4 GB of DDR an AMD 4200+, and it was a GREAT, reliable computer!
Then Intel jumped ahead of AMD with Core 2, and AMD hasn't caught up...
Next, I built an nForce 680i system with a Q6600 & 8 GB of DDR 2... It was a VERY GOOD, mostly reliable computer, but I think Nvidia had some chip-set issues working with Nvidia though it worked fine... some of the drivers were not what they could have been.
Then the problems started:
1. 680i motherboard craps out in that the NICs stopped working, so I send it back to ASUS warranty thinking it would be quick to get it replaced.
2. After three weeks of waiting, they sent me back the same "repaired" motherboard only it didn't work at all! It was WAY worse!
3. I sent it back to which they said "you scratched a trace." I called them on their B.S. and demanded they substantiate it with a picture. They sent a picture... I wrote back saying, "If you are going to make up evidence that I scratched it, take a picture of an Orange motherboard not a green one."
4. Got a 780i as a replacement
5. 6 months later it craps out... Got another 780i as a replacement.
6. Now my computer is doing the same ****... Not POSTing each time I turn it on... Same freak-en problem as 6 months ago... Need another motherboard.
So, I decided I am going to get:
1. A motherboard with an Intel NorthBridge & SouthBridge chipset... and it WILL be made by Intel not MSI, Gigabyte, or any others, which I am sure are probably fine.
2. I will buy a new Intel processor & new memory at the same time.
I looked all OVER Newegg! The Z68 sounded cool, but it was very new, so I figured something with a proven track record... That got me looking at the H67, P67, and Q67.
1. I realized H67 is the no-thrills home-user board with Integrated Graphics and NO processor overclocking (which, I don't do anyway).
2. The P67 has all the thrills. It is a professional series board without Integrated Graphics and it supports Overclocking (if the processor does). I really liked this given it has no integrated video to deal with disabling though presumably adding a Video card is all it takes to disable the on-board video anyway.
3. I looked long and hard at the Q67; since, it is built for Corporate environments. Overall, it seems like an H67 board, but again I don't want support for Integrated Graphics. The only thing it has support for is VT-d, which I guess would be useful if running Hyper-V or ESX allowing a VM to directly be assigned a physical device.
I chose the P67, which doesn't support VT-d... Then I chose the i7-2600k. I was going to go with the i7-2600; since, I don't overclock & the plain 2600 has VT-d... until I found out that is ONLY with a Q-Series motherboard.
Here is what I bought:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121512
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233190
$504.97 out the door. I will have to QUIT doing SLI though, but that is my goal! I am NOT a gamer anymore and would rather have one good Video card than two; since, there is less power usage and less that can go wrong.
I am transitioning into a mature person's computer.
I used to have:
1. Two DVD Burners
2. A RAID 5 (3 x 250 GB) <== Imagine Data Recovery from this!
3. A Spare Plain Drive
4. SLI
I already changed to this:
1. One Blue Ray that can also be a DVD Burner
2. A RAID 1 (2 x 2 TB) <== Very easy data recovery & no CPU waste calculating parity
3. Still have the Spare drive
4. Still have SLI
After this upgrade:
1. One Blue Ray
2. RAID 1
3. Storage Drive will be mirrored to my File Server.
4. Only one Video Card
I am also not going to have a Mix of different chip-sets...
I guess you are kind of asking for trouble as a beta tester when you have an Nvidia chipset right after they make the switch to Intel from AMD, then ask it to do SLI & RAID 5 (without a controller), and an extra HDD & Optical drive to stress the PSU even more.
Does anyone here have a recommendation for a good Video Card? My 8800GTs are a bit past their prime. Also do you guys like NVidia or ATI more?
You build computers all the time..., so I value your opinions considering I do like 1 or 2 a year.
I used to have:
1. Two DVD Burners
4. SLI
4. Still have SLI
After this upgrade:
1. One Blue Ray
2. RAID 1
