Valid Network Speed Test?
Velvis
Medfield, MA
I am trying to pin down a network issue with one particular Mac computer. Is there a legitimate speed test that is accurate? I have been using Verizons, Ookla, speedtest.org and they all vary widely in the results.
That's kind of a vague request as it depends what you're trying to figure out. All of those speedtest websites will vary, sometimes by a lot. Doing speed tests with the ISP tools are also misleading since they are "on the inside".
If I use those website based ones I'll use 3, usually speedtest.net, megapath, and the ISP. I'd done some troubleshooting work with providers that used iperf. It's much more sophisticated as you can specify the payload, which most of the other's don't allow. So you can specify a 5gb file for an example. But the downside is it's kind of hard to find a public iperf server that works 100%. Another thing I'll use is a continuous ping to both a FQDN and the corresponding IP of that FQDN. Sometimes the problems are related to DNS.
The key point is most of those website ones don't allow a continuous test, usually a payload in the 10's of MB size.
Knew a tech who used to diagnose whether a router issue was fixed by running ping tests and a few other scripted things like dns lookup which I think will give you a time in seconds for the lookup, and also transferring file to another local machine to rule out a local issue.
Also, double check with the current plan the customer is on with ISP, I've had plenty of cases where they had the slowest speed and it ended up being a mistake, they upgraded package and for whatever reason the ISP rolled back to the old speed.
