meanderer
- Brooklyn, NY
My client brought in a laptop that he claimed to have liquid spilled on. Upon first inspection I do not see any water stains, meaning if there was any water it was dried off or cleaned off in some ways.
The client told me that he wasn't able to click or work on anything on the computer. I booted it up and it worked mostly fine except that:
1. the mouse point would sometimes jumps all the way to the right edge of the screen when I use the track pad (very intermittent and not repeatable)
2. a few top row of keys are "linked", for example when I press the e key both e and 3 would be activated or it says 3e. The same happens with r linked with 4, o with 9, i and 8.
I do not see any stains under the keyboard. I plugged in a USB keyboard and mouse set and unplugged the laptop keyboard. the USB parts works perfectly fine.
I am ready to order a replacement keyboard. Since it's over the labor day weekend, I would have to wait a while for parts. I would like to ask the techs here:
1. how likely the KB is the sole problem on the laptop? I think the liquid has seeped into the traces and shorted out the respective lines, causing both keys to activate when in fact only 1 key is pressed.
2. how likely the keyboard controller on the main board is "fried"? Is it possible that the liquid to have damaged the keyboard controller on the main board somehow so it now only works partially like this?
I have not disassemble the entire thing because I don't see a deep extent of damage, should I go ahead and take it apart first?
the laptop in question is a compaq cq60, don't think it really really matters except what part to get.
Thanks for helping.
Thanks for helping.
