mslink
- arizona bay
Hi, I need some advice on this for a client. I've done smaller hot-spots (in one building) but nothing like this. I know I am skilled enough to take it on but I would like some advice & questions answered.
I got a call the other day from a restaurant owner who wants to install a wifi hot spot in his restaurant and send the signal over to two other buildings. He only owns the restaurant and wants to set up a hot spot to offer Internet to two other buildings right by his. Equipment ideally is all mounted on his roof / building. Building one is a convention center type building (all open area once inside mainly) starting at 200' away and the back end reaching about 800'/900' away from his restruant. The 2nd building is a hotel about 1,000' away with the back end being about 1,300 feet away. He also wants wifi setup in his restaurant for his customers separate from his own private wifi. I could use any advice / insight on this if you know anything and would appreciate it very much.
The wifi in his restaurant for his customers I am just going to place a router behind the bar, and if necessary an extender on the far end but one router should handle his whole restaurant fine as it's not very big. His private wireless (for his personal / staff use I guess - I don't know why he wants both) will just include a router in his back office like normal. He's having a T1 ran in and also has DSL (I'm going to suggest to him to keep the DSL too) all that is running in to the back office. A switch will be setup as well for his security cameras, computers, the other routers and the feed for the hot spot (may also need some sort of firewall to protect his computers from the hot spot, where?). From his roof it is a straight shot to both buildings (only parking lot between). From the back office I'll run the cables up to the roof for the hot spot feed where antenna's will be mounted to shoot the Internet over...
Now I know normally what you would do is have an antenna from his roof shooting the Internet to both buildings and then have an antenna/extender on the other buildings to boost the signal into each individual building. That's not possible because he only owns the one and wants everything there. If you have a better idea or don't think this will work let me know. I am still putting the rest of this together.
With cables ran to the roof for the hot spot feed I was going to install at least two (1 for ea building) AP / atenna's. I was going to use Value Point (http://www.valuepointnet.com/products/ruggedap/index.html). I've used them before and am not sure what other companies sell gear like that. Another area I have not decided on is to use Value Point hardware/software to manage the hot spot or to get a separate hot spot router and run the two antennas off of that. What do you think?
I am still working out some of the details and best way to go so if you have any ideas or information or hardware I should take a look at please please let me know. Is the way I am planning on doing this right? Do you think shooting one (or 2 or 3 if needed) of these AP's/antenna's at the hotel building alone will get the signal there strong enough and into the building for people to use strong enough? What about the other building? I am sure the signal will reach, would you suggest using one or two?
If you have any questions about site let me know. I am going to find out in the morning what that hotel is made out of. Which will also help me figure this out. Any help is appreciated very much!
