Will not wake from Sleep mode Help!!
Toledo, Ohio
I have a clients computer here and it is having problems when I try to wake it from sleep ( the screen will come on you can move the mouse freely and you can click on the start menu, icons, etc. but nothing will open, you can try to bring up TM but still nothing will show up, the HD indicator light blinks at a steady rate and you have to do a cold shutdown and it will come back up as a resume windows session ( which it will work from that point or you can delete resume point and do a fresh restart and it works fine untill it goes back into sleepmode.
any suggestions would be greatly appreciated.
Here are the specs
Summary
Operating System
MS Windows 7 Ultimate 64-bit
CPU
Intel Core i7 920 @ 2.67GHz 51 °C
Bloomfield 45nm Technology
RAM
8.0GB Single-Channel DDR3 @ 534MHz (7-7-7-20)
Motherboard
ASUSTeK Computer INC. P6T (LGA1366) 46 °C
Graphics
VX2433wm @ 1440x900
ATI Radeon HD 4600 Series (ATI AIB) 43 °C
Hard Drives
1465GB Seagate ST31500341AS ATA Device (IDE) 35 °C
1465GB Seagate ST31500341AS ATA Device (IDE) 36 °C
488GB Seagate ST3500320AS ATA Device (Unknown Interface)
Optical Drives
HL-DT-ST BD-RE WH08LS20 ATA Device
TSSTcorp CDDVDW SH-S223Q ATA Device
Audio
HTO STRIKER 7.1
Operating System
Installation Date: 13 September 2010, 20:36
Serial Number: ***************************
CPU
Intel Core i7 920
Cores 4
Threads 8
Name Intel Core i7 920
Code Name Bloomfield
Package Socket 1366 LGA
Technology 45nm
Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Family 6
Extended Family 6
Model A
Extended Model 1A
Stepping 4
Revision C0/C1
Instructions MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T
Bus Speed 133.6 MHz
Rated Bus Speed 2405.4 MHz
Stock Core Speed 2666 MHz
Stock Bus Speed 133 MHz
Average Temperature 51 °C
Caches
L1 Data Cache Size 4 x 32 KBytes
L1 Instructions Cache Size 4 x 32 KBytes
L2 Unified Cache Size 4 x 256 KBytes
L3 Unified Cache Size 8192 KBytes
Core 0
Core Speed 2806.3 MHz
Multiplier x 21.0
Bus Speed 133.6 MHz
Temperature 51 °C
Thread 1
APIC ID 0
Thread 2
APIC ID 1
Core 1
Multiplier x 21.0
Bus Speed 133.6 MHz
Temperature 52 °C
Thread 1
APIC ID 2
Thread 2
APIC ID 3
Core 2
Multiplier x 21.0
Bus Speed 133.6 MHz
Temperature 52 °C
Thread 1
APIC ID 4
Thread 2
APIC ID 5
Core 3
Multiplier x 21.0
Bus Speed 133.6 MHz
Temperature 50 °C
Thread 1
APIC ID 6
Thread 2
APIC ID 7
RAM
Memory slots
Total memory slots 6
Used memory slots 2
Free memory slots 4
Memory
Type DDR3
Size 8192 MBytes
Channels # Single
DRAM Frequency 534.5 MHz
CAS# Latency (CL) 7 clocks
RAS# to CAS# Delay (tRCD) 7 clocks
RAS# Precharge (tRP) 7 clocks
Cycle Time (tRAS) 20 clocks
Command Rate (CR) 2T
SPD
Number Of SPD Modules 4
Slot #1
Type DDR3
Size 2048 MBytes
Manufacturer Corsair
Max Bandwidth PC3-8500F (533 MHz)
Part Number CM3X2G1333C9DHX
SPD Ext. EPP
JEDEC #4
Frequency 685.7 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 26
tRC 35
Voltage 1.500 V
JEDEC #3
Frequency 609.5 MHz
CAS# Latency 8.0
RAS# To CAS# 8
RAS# Precharge 8
tRAS 23
tRC 31
Voltage 1.500 V
JEDEC #2
Frequency 533.3 MHz
CAS# Latency 7.0
RAS# To CAS# 7
RAS# Precharge 7
tRAS 20
tRC 27
Voltage 1.500 V
JEDEC #1
Frequency 457.1 MHz
CAS# Latency 6.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 18
tRC 24
Voltage 1.500 V
Slot #2
Type DDR3
Size 2048 MBytes
SPD Ext. EPP
JEDEC #4
Frequency 685.7 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 26
tRC 35
Voltage 1.500 V
JEDEC #3
Frequency 609.5 MHz
CAS# Latency 8.0
RAS# To CAS# 8
RAS# Precharge 8
tRAS 23
tRC 31
Voltage 1.500 V
JEDEC #2
Frequency 533.3 MHz
CAS# Latency 7.0
RAS# To CAS# 7
RAS# Precharge 7
tRAS 20
tRC 27
Voltage 1.500 V
JEDEC #1
Frequency 457.1 MHz
CAS# Latency 6.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 18
tRC 24
Voltage 1.500 V
Slot #3
Type DDR3
Size 2048 MBytes
SPD Ext. EPP
JEDEC #4
Frequency 685.7 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 26
tRC 35
Voltage 1.500 V
JEDEC #3
Frequency 609.5 MHz
CAS# Latency 8.0
RAS# To CAS# 8
RAS# Precharge 8
tRAS 23
tRC 31
Voltage 1.500 V
JEDEC #2
Frequency 533.3 MHz
CAS# Latency 7.0
RAS# To CAS# 7
RAS# Precharge 7
tRAS 20
tRC 27
Voltage 1.500 V
JEDEC #1
Frequency 457.1 MHz
CAS# Latency 6.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 18
tRC 24
Voltage 1.500 V
Slot #4
Type DDR3
Size 2048 MBytes
SPD Ext. EPP
JEDEC #4
Frequency 685.7 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 26
tRC 35
Voltage 1.500 V
JEDEC #3
Frequency 609.5 MHz
CAS# Latency 8.0
RAS# To CAS# 8
RAS# Precharge 8
tRAS 23
tRC 31
Voltage 1.500 V
JEDEC #2
Frequency 533.3 MHz
CAS# Latency 7.0
RAS# To CAS# 7
RAS# Precharge 7
tRAS 20
tRC 27
Voltage 1.500 V
JEDEC #1
Frequency 457.1 MHz
CAS# Latency 6.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 18
tRC 24
Voltage 1.500 V
Motherboard
Manufacturer ASUSTeK Computer INC.
Model P6T
Version System Version
Chipset Vendor Intel
Chipset Model X58
Chipset Revision 12
Southbridge Vendor Intel
Southbridge Model 82801JR (ICH10R)
Southbridge Revision 00
Temperature 46 °C
BIOS
Brand American Megatrends Inc.
Version 1303
Date 03/08/2010
Graphics
Monitor
Name VX2433wm on ATI Radeon HD 4600 Series
Current Resolution 1440x900 pixels
Work Resolution 1440x852 pixels
State enabled, primary, output devices support
Monitor Width 1440
Monitor Height 900
Monitor BPP 32 bits per pixel
Monitor Frequency 60 Hz
Device \\.\DISPLAY1\Monitor0
GPU RV730
Device ID 1002-9490
Subvendor ATI AIB (1787)
Technology 55 nm
Die Size 145 nm?
Transistors 514 M
Release Date Sep 10, 2008
DirectX Support 10.1
DirectX Shader Model 4.1
OpenGL Support 3.0
Temperature 43 °C
Core Voltage 1.200 V
BIOS Version 113-SBSK2G05-10R-00
ROPs 8
Shaders 320 unified
Bus Width 128 Bit
Pixel Fillrate 4.0 GPixels/s
Texture Fillrate 16.0 GTexels/s
Hard Drives
Manufacturer Seagate
Form Factor 3.5"
Interface IDE
Capacity 1465GB
Real size 1,500,301,910,016 bytes
S.M.A.R.T
01 Read Error Rate 113 (099 worst) Data 00032A49F2
03 Spin-Up Time 100 (092) Data 0000000000
04 Start/Stop Count 099 (099) Data 00000004AF
05 Reallocated Sectors Count 100 (100) Data 0000000000
07 Seek Error Rate 072 (060) Data 0000EC95DB
09 Power-On Hours (POH) 090 (090) Data 00000022BA
0A Spin Retry Count 100 (100) Data 0000000000
0C Device Power Cycle Count 100 (100) Data 0000000148
B8 100 (100) Data 0000000000
BB 100 (100) Data 0000000000
BC 100 (098) Data 0000030005
BD High Fly Writes (WDC) 081 (081) Data 0000000013
BE Temperature Difference from 100 065 (053) Data 0023230023
C2 Temperature 035 (047) Data 0000000023
C3 Hardware ECC Recovered 038 (026) Data 00032A49F2
C5 Current Pending Sector Count 100 (100) Data 0000000000
C6 Uncorrectable Sector Count 100 (100) Data 0000000000
C7 UltraDMA CRC Error Count 200 (200) Data 0000000000
F0 Head Flying Hours 100 (253) Data 00000015B1
F1 100 (253) Data 00ECFF3C6A
F2 100 (253) Data 00F5C92806
Temperature 35 °C
Temperature Range ok (less than 50 °C)
Status Good
Partition 0
Partition ID Disk #0, Partition #0
Disk Letter E:
File System NTFS
Volume Serial Number 78A55CE8
Size 1397GB
Used Space 183GB (14%)
Free Space 1214GB (86%)
Form Factor 3.5"
Serial Number 9VS0LFHK
Interface IDE
Capacity 1465GB
S.M.A.R.T
01 Read Error Rate 116 (099 worst) Data 0006375D1E
03 Spin-Up Time 094 (092) Data 0000000000
04 Start/Stop Count 099 (099) Data 000000049D
05 Reallocated Sectors Count 100 (100) Data 0000000010
07 Seek Error Rate 072 (060) Data 000112AEE0
09 Power-On Hours (POH) 090 (090) Data 00000022B4
0A Spin Retry Count 100 (100) Data 0000000001
0C Device Power Cycle Count 100 (037) Data 0000000149
BC 100 (099) Data 00000D000E
BD High Fly Writes (WDC) 046 (046) Data 0000000036
BE Temperature Difference from 100 064 (051) Data 0024240024
C2 Temperature 036 (049) Data 0000000024
C3 Hardware ECC Recovered 031 (018) Data 0006375D1E
Temperature 36 °C
Status Good
Partition 0
Partition ID Disk #1, Partition #0
Disk Letter D:
File System NTFS
Volume Serial Number 104E5021
Size 1397GB
Used Space 393GB (29%)
Free Space 1005GB (71%)
Form Factor 3.5"
Cache Size 8MB
Interface Unknown Interface
Serial Number 9QM5RK9P
Capacity 488GB
Real size 500,107,862,016 bytes
S.M.A.R.T
Status Bad
Partition 0
Partition ID Disk #2, Partition #0
Disk Letter C:
File System NTFS
Volume Serial Number F4C9EA58
Size 466GB
Used Space 69GB (15%)
Free Space 397GB (85%)
Optical Drives
Media Type DVD Writer
Name HL-DT-ST BD-RE WH08LS20 ATA Device
Availability Running/Full Power
Capabilities Random Access, Supports Writing, Supports Removable Media
Config Manager Error Code Device is working properly
Config Manager User Config FALSE
Drive F:
Media Loaded FALSE
SCSI Bus 1
SCSI Logical Unit 0
SCSI Port 3
SCSI Target Id 0
Status OK
Name TSSTcorp CDDVDW SH-S223Q ATA Device
Drive G:
Media Loaded FALSE
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 2
SCSI Target Id 0
Status OK
Audio
Sound Cards
ATI High Definition Audio Device
USB Audio Device
HTO STRIKER 7.1
USB Audio Device
Playback Devices
Digital Audio (S/PDIF) (2- High Definition Audio Device)
Digital Output (HTO STRIKER 7.1)
Speakers (HTO STRIKER 7.1) (default)
Recording Devices
Microphone (HTO STRIKER 7.1)
Line In (HTO STRIKER 7.1)
Wave (HTO STRIKER 7.1)
Microphone (HP Prem AF Webcam KQ245AA) (default)
Stereo Mix (HTO STRIKER 7.1)
Aux (HTO STRIKER 7.1)
CD Player (HTO STRIKER 7.1)
SPDIF In (HTO STRIKER 7.1)
Peripherals
HID Keyboard Device
Device Kind Keyboard
Device Name HID Keyboard Device
Vendor Logitech
Location USB Input Device
Driver
Date 6-21-2006
Version 6.1.7600.16385
File C:\Windows\system32\DRIVERS\kbdhid.sys
File C:\Windows\system32\DRIVERS\kbdclass.sys
HID-compliant mouse
Device Kind Mouse
Device Name HID-compliant mouse
Vendor Logitech
Driver
Date 6-21-2006
File C:\Windows\system32\DRIVERS\mouhid.sys
File C:\Windows\system32\DRIVERS\mouclass.sys
USB Video Device
Device Kind Camera/scanner
Device Name USB Video Device
Vendor Unknown
Comment HP Prem AF Webcam KQ245AA
Location 0000.001d.0007.002.001.000.000.000.000
Driver
Date 6-21-2006
File C:\Windows\system32\drivers\usbvideo.sys
USB Audio Device
Device Kind Audio device
Device Name USB Audio Device
Vendor Unknown
Comment USB Audio CODEC
Location 0000.001d.0001.001.000.000.000.000.000
Driver
Date 7-13-2009
File C:\Windows\system32\drivers\USBAUDIO.sys
File C:\Windows\system32\drivers\drmk.sys
File C:\Windows\system32\drivers\portcls.sys
File C:\Windows\system32\WMALFXGFXDSP.dll
File C:\Windows\system32\SysFxUI.dll
USB Audio Device
Vendor Unknown
Driver
Date 7-13-2009
Disk drive
Device Kind USB storage
Device Name Disk drive
Vendor GENERIC
Comment Generic Mini SD Reader USB Device
Location USB Mass Storage Device
Driver
Date 6-21-2006
File C:\Windows\system32\DRIVERS\disk.sys
Disk drive
Vendor GENERIC
Comment Generic USB CF Reader USB Device
Driver
Date 6-21-2006
Disk drive
Vendor GENERIC
Comment Generic USB MS Reader USB Device
Driver
Date 6-21-2006
Disk drive
Vendor GENERIC
Comment Generic USB SD Reader USB Device
Driver
Date 6-21-2006
Disk drive
Vendor GENERIC
Comment Generic USB SM Reader USB Device
Driver
Date 6-21-2006
Disk drive
Vendor OCZ
Comment OCZ RALLY2 USB Device
Driver
Date 6-21-2006
Network
You are connected to the internet
Connected through Realtek PCIe GBE Family Controller
IP Address 192.168.1.4
External IP Address 72.240.231.152
Adapter Type Ethernet
WinInet Info
LAN Connection
Local system uses a local area network to connect to the Internet
Local system has RAS to connect to the Internet
Wi-Fi Info
Wi-Fi not enabled
WinHTTPInfo
WinHTTPSessionProxyType No proxy
Session Proxy
Session Proxy Bypass
Connect Retries 5
Connect Timeout 60000
HTTP Version HTTP 1.1
Max Connects Per 1.0 Servers INFINITE
Max Connects Per Servers INFINITE
Max HTTP automatic redirects 10
Max HTTP status continue 10
Send Timeout 30000
IEProxy Auto Detect No
IEProxy Auto Config
IEProxy
IEProxy Bypass
Default Proxy Config Access Type No proxy
Default Config Proxy
Default Config Proxy Bypass
Form Factor 3.5"
Cache Size 8MB
Capacity 488GB
S.M.A.R.T
Status Bad
Partition 0
Disk Letter C:
File System NTFS
Size 466GB
Don't see anything wrong with this picture?:eek:
@Mac - Hey Man, you are very good to catch that that. That was way too much information for me.
Thanks eric76. I wish they were all that easy. Usually most bad drives I see I are pretty much long gone by the time a SMART failure is flagged. I'm surprised that machine is still booting. OP better think about seeing how important the clients data is.
Yeah, I skipped the post and jumped right to the replies to leach ideas to support. lol
Did the SMART fail in CrystalDisk? I always run that as part of my basic troubleshooting. Actually I run it on every machine I touch, usually one of the first things.
the error is false - I ran 2 other HD diagnostics and they came back clean- this was a false read using the program called speccy
Still, from what you've described symptom wise, I'd still back up/image the clients drive and download an actual Seagate drive diagnostic and do more testing to be sure. All (speccy or what ever you used) is doing is pulling SMART attribute data from the drive itself, and maybe its not consistently flagging failures, but there still looks to be an issue. Maybe that's why its still booting while having a SMART failure.
Other than that what else have you done to make sure it is not the drive? Don't see much else posted..
I ran the seagate diagnostics and there was a failure , I cloned the drive and put in a new drive everything is working perfect
thanks to everyone that helped
I've always considered it a good rule of thumb to, whenever possible, run the diagnostics of the manufacturer. If Seagate is willing to admit that their drive is bad, they're probably right.
"move the mouse freely and you can click on the start menu, icons, etc. but nothing will open, you can try to bring up TM but still nothing will show up, the HD indicator light blinks at a steady rate"
Try run the chkdsk C: /r/v command at DOS.
Hope this helps!
Bill
Tech manager
