HCHTech
- Pittsburgh, PA - USA
We've got a new build on the bench now that has pointed out what seems like a change in functionality that I'd like to clarify.
So this is a Ryzen 7, Asus Prime450 MB (fully updated BIOS), Samsung NVMe drive for the OS, and a 4TB WD Black for data storage.
In the past, I am sure that we:
Then, more perplexingly, we removed all partitions from that drive with PartedMagic, but then Windows would no longer boot, even if the drive was removed again. The only way forward was to reinstall Windows again. We went through this procedure twice just to make sure we didn't fat-finger something.
We also tried taking that drive to a separate Linux machine and removing all partitions. The behavior was the same, Windows would not boot when the drive was reinstalled, and would no longer boot if it was removed again. We went through the BIOS multiple times to make sure nothing had changed. We tried bcdedit from a command prompt of a Win10 installer, it detected the existing install, but could not repair the boot record.
So we did what I guess we should have done from the start and installed Windows without the storage drive connected. Then (having removed all partitions from it again), we shut down the machine and reconnected the storage drive. Now upon boot, we could initialize the disk as GPT and proceed as normal.
I swear we didn't need to do this dance in the past. We don't do many machines with extra storage drives, but I know we had one this past fall and don't remember any of this nonsense with that build.
Did something change with the Win10 install that affected how secondary drives are treated? Shouldn't we have been able to go into disk management and initialize the disk as GPT the first time we got into Windows after the install completed? If not, I guess I have a procedure to revise.
- Assembled the machine with all components
- Installed Win10
- Initialized the storage drive as GPT when prompted or in disk manager, followed by a format
- Finished prep for delivery
