BrandonTech
- Alabama
Had a client bring in an HP Envy m6-w101dx laptop that suddenly wouldn't show anything on the display after updating. There seems to be some type of incompatibility between Win10 and the Intel HD 5500 graphic adapter. It was updated on HP's site as recently as today (5/22), but nothing I have done seems to have made a difference. Each and every time I have tried any version of this driver, I get the sound that a device has attached (like you get when plugging in USB drive) and an immediate black screen.
You can get output on the display when booting into Safe Mode. I go that route to set the display adapter to the MS basic adapter. The laptop will display when using the built-in Microsoft Basic Display Adapter for the display in Safe and Normal modes.
I had to go as far as preventing device updates via the registry to prevent Win10 from auto-installing the Intel driver. I also ended up disabled Windows Update Services as a manual check for updates still installed the Intel driver.
I'm not happy leaving it this way, but may have to for now. I haven't seen one so persistently fail when trying to use the recommended driver. Leaving it like this disables the HDMI port on the side which is another reason I don't like leaving it with the basic display driver. This client uses this port.
Has anyone experienced this issue before? Any input you would like to provide is appreciated.
