DavidH
- Mangawhai Heads, New Zealand
Hi,
I have a desktop that boots to a black screen with a white mouse cursor. This appears to be a common problem given the number of hits on google, though I have not seen it before.
Unfortunately, none of the so-called solutions I have seen seem to be appropriate for my case here. Booting in safe mode, boot from last known good configuration all have the same outcome - a black screen. Other solutions that require access to command lines , device managers etc wont work. Any stuff like that has to be offline which makes it tricky, to say the least.
Before I give up and blow it away and reinstall I was wondering if the collective mind had seen this issue and might have any suggestions?
Cheers!
Cheers!
