I have a Compaq box that based on the owners description I believe is a virus based issue. They stated that the machine was giving them pop ups for Virus Scan 2010 or something of that nature and the box was protected by Norton with what they tell me were updated definitions. That issue when on for a month or two then one day the machine stops booting windows.
Issue:
-Start Machine and all post pass then after you get the start up menu
-If you select “normal” you get the Windows Splash Screen for about 20 sec then the box reboots
- If you select safe mode you get about 20-30 lines of files before it begins the reboot mode
Actions
-Placed windows xp disk in drive and set bios to boot from drive – NOTHING
-Placed Acronis Rescue Boot Disk in – NOTHING
-Then for giggles placed a few other “boot” disk in and you got it – NOTHING
- I removed the drive and placed into a spare machine as slave and scanned the disk with 0% fragmentation and 0 disk errors. I made a back up using Acronis True Image and all appears normal.
- I pulled the DVD drive and works fine on different machine.
So I am unable to access Windows repair console and unable to boot any disk. Yet the HD checks out good on several checks that I have ran. What am I missing here and did I explain it clear?
Issue:
Actions
