I have just performed a clean install of vista 32bit home pre. No matter what I can't get the audio driver to install right, I've downloaded the driver from hp, the audio driver error is:
This device cannot find enough free resources that it can use. (Code 12)
If you want to use this device, you will need to disable one of the other devices on this system.
two two issues I have here
Name: High Definition Audio Controller
Description: High Definition Audio Controller
Manufacturer: Microsoft
Device ID: PCI\VEN_10DE&DEV_07FC&SUBSYS_2A64103C&REV_A1\3&2411E6FE&0&48
PNP Device ID: PCI\VEN_10DE&DEV_07FC&SUBSYS_2A64103C&REV_A1\3&2411E6FE&0&48
Service: HDAudBus
Class GUID: {4d36e97d-e325-11ce-bfc1-08002be10318}and one of the two standard dual pci ide controllers has an issue:
Name: Standard Dual Channel PCI IDE Controller
Description: Standard Dual Channel PCI IDE Controller
Manufacturer: (Standard IDE ATA/ATAPI controllers)
Device ID: PCI\VEN_10DE&DEV_056C&SUBSYS_2A64103C&REV_A1\3&2411E6FE&0&40
PNP Device ID: PCI\VEN_10DE&DEV_056C&SUBSYS_2A64103C&REV_A1\3&2411E6FE&0&40
Service: pciide
Class GUID: {4d36e96a-e325-11ce-bfc1-08002be10318}
Audio works fine in linux live cd, this driver stuff can drive me crazy sometimes! ideas?
Service: HDAudBus
Service: pciide
