davenz
- New Zealand
Probably been asked many times, but what is the best and most cost effective drive cloning software for Windows PCs?
Thanks
Thanks
In general or for DATA RECOVERY situations?Probably been asked many times, but what is the best and most cost-effective drive cloning software for Windows PCs?
Thanks
Thanks
I prefer Macrium Reflect.For general use. For example, moving to a larger HDD, or HDD to SSD. Thanks
I have that too but only use it to resize partitions.I like Mini Tool Partition Wizard.
I second and third this. Reflect is an awesome product. Been using it for years, though I bought it because you know, commercial use.I prefer Macrium Reflect.
But did you purchase it or pirate it? And they only list version 8 on their site. You know I had to give you some flack.I just upgraded to version 9
But did you purchase it or pirate it? And they only list version 8 on their site. You know I had to give you some flack.![]()
Yep, Reflect every time.I second and third this. Reflect is an awesome product. Been using it for years, though I bought it because you know, commercial use.
I'm a Macrium reseller and I've been using it for probably 10 or more years now. It's an incredible product. Very flexible (especially with the built-in scripting features) and it's very reliable.
That feature has been there for for as long as I can remember in Reflect, although to be fair it's not immediately obvious if you're not familiar with the interface. You have to manually drag and drop the individual partitions and/or edit their properties to resize them. It's not fully automatic like it is with some software but, to be fair, it's not always obvious which partition(s) needs to be resized. Personally I prefer the greater control over partition resizing that Reflect gives.There's no on the fly automatic partition adjustment for imaging/cloning to a smaller (or bigger) drive.
And I can honestly say that Reflect's drive imaging has NEVER let me down, but then I always enable image verification.
Are the OEM versions of Acronis technician friendly license wise? They obviously only work with one OEM's drives, but would you be able to backup on a WD drive and recover on a Seagate drive as long as you use the correct versions on each side? Or are the backups tagged somehow?
I get NEW clients because of that. NEVER has a past client had that issue unless someone other than the client does something else on the computer to messs up my setup and training of the client.a few days later she gladly handed over $385 to an online browser scam, says to call this number you are infected and nothing will close down. you know the one
