MichaelEC
- Sparta, IL
I have found that in addition to disconnecting the internet while installing, downloading in small groups seems to help speed the process if there are a lot of updates.
one of the first things wsus offline does is put the latest update client on.I found this post very helpful.
http://wu.krelay.de/en/2016-07.htm
After reading that I found the following steps worked somewhat well after a Win764SP1 fresh install.
1. Disconnect network cable from PC.
2. Download appropriate Windows Update Client to a flash drive on another PC.
3. Install that one update.
4. Reboot.
5. Run WSUSOffline as normal while network is disconnected.
6. Eventually finish offline and revert to online.
It could still take hours but will be much quicker than online updates. Make sure you're offline when you run offline updates.Having not previously needed that I was reluctant to accept it from any site initially. I did run WSUSOffline and am still stuck with a seemingly endless waiting period for updates... Still trying to perfect my Win 7 x64
"SP2"ISO to reduce this nuisance... No luck yet.
Somewhere in these forums I spoke of using "RT 7 Lite" complete with links to the program (make sure you get the correct bit version if/when you should download it.) I used it to make an installable version of Win7Pro64bit with several rollups and other updates in the installable software (I use USB for my media.) If you search for my article / message you will find that what I have done helps greatly. In fact the latest image I created runs as an unattended installation of the O/S with the extra updates. All I do afterwords is run WSUS Offline, install extra software, then finish up with running Windows 7 updates. It has worked great for the last 3 or 4 installs I've done.WSUS Offline update did the trick for me at last. There were only 25 or so updates remaining and I didn't have to wait to get them. It downloaded a couple of gigabytes of data and I don't know which was the critical bit or I'd try to add those to the ISO.
Just did this again - on a pretty plain install of Win7 Home Prem., 64 bit. Worked like a dreamThis is what I do now on Win 7.
1. Install Win 7 with SP1
2. Install April 2015 Service Stack KB3020369
3. Install Rollup KB3125574
4. Install WSUS update KB3138612
5. Install IE11
6 Setup Microsoft Update
7. Run Microsoft Update
Hi
Has anybody found a real fix for the slow update process after installing windows 7 sp1 ?
It sticks on checking for updates for ages, got a laptop here that has been trying for 20 hrs now.
Regards
Glenn
Are we going to be able to install these 2 specific KB when MS reverts to roll-ups in October?Just download/install KB3020369 and KB 3172605 (combined..takes under 5 minutes on a slow rig, under 2 minutes on a fast rig)....reboot, let it sniff for updates (around 5-15 minutes)....tons of updates will show up like normal, download/install, done.
Those 2 updates get rid of that painfully long "first check for updates" that seems like a takes a day or overnight lately.
Some rigs, depending on what level Windows is, suggest you stop the Windows Update service before running the downloads above.
Been doing it this way for months...works well. No more hours of wait. Just a couple of minutes at the most.
Yes.Are we going to be able to install these 2 specific KB when MS reverts to roll-ups in October?
