allanc
- Toronto, Ontario, Canada
Good. I just d/l these two KB .. just in case.Yes.
This well liked post by River Valley has become my defacto standard. No more waiting. Now it's how fast is the computer and connection.
https://www.technibble.com/forums/threads/windows-7-updates.69654/#post-546701
I just wanted to say that I tried this method on three computers yesterday and it worked as advertised.Just download/install KB3020369 and KB 3172605 (combined..takes under 5 minutes on a slow rig, under 2 minutes on a fast rig)....reboot, let it sniff for updates (around 5-15 minutes)....tons of updates will show up like normal, download/install, done.
Those 2 updates get rid of that painfully long "first check for updates" that seems like a takes a day or overnight lately.
Some rigs, depending on what level Windows is, suggest you stop the Windows Update service before running the downloads above.
Been doing it this way for months...works well. No more hours of wait. Just a couple of minutes at the most.
You can still upgrade. Been doing many since the end of the offer.Great posts this is going to help next time I have to do a Win 7 install
there will be more since free win 10 has finnished
I've been wanking around with this as well. Dusted off a W7 Home Prem machine that has not been on since 11/2014. Of course updates hang. One suggestion by @River Valley Computer in this thread - https://www.technibble.com/forums/threads/windows-7-updates.69654/#post-546604 - has proved invaluable. Make sure the computer is not connected to the Internet and the downloaded installations run much quicker.
Edit: The below are the kb's I installed and their order. After the last one Update started behaving normally. Another problem I had was, for some reason, when searching and downloading I was getting pointed to the x86 instead of x64 files. Maybe because the box is a bottom dollar Lenovo.
kb2775511
kb3020369
kb3138612
kb3172605
I think you've posted this elsewhere Mark and it has worked great for me on machines that were not new installs but still stuck on Windows 7 Updates. What I didn't realize is that the first update (KB2775511) seems to make a (log/index?) file in the same directory as it is in. Since I ran this update from a USB Flash drive on one machine it failed on the next machine and I am assuming it's because I didn't delete that file first. (Work in progress. Trying to reboot - Stuck at "Preparing to configure.....pfffft")
Anyone else seen this on KB2775511?
^ This.. To help even further.This is what I do now on Win 7.
Without making me go look these up. what specifically are they?I have also came across this issue with fresh installs of windows 7 pro. I have solved the issue by installing the following updates and for safe measure booting between them.
Download and install the following 2 updates:
1. KB3102810
2. KB3112343
No special procedure, After they are installed you should be able to check for updates and it should complete within a few minutes.
coffee
I've had a laptop running since 11.00am last Friday. Its now 10.00pm Sunday and still no updates.
Tried all of the suggestions from these forums, nada!
Just kicked off WSUS Offline so hopefully that will work, need it out tomorrow...
Out of curiousity have you rebooted the computer between tries (for updates)?I've had a laptop running since 11.00am last Friday. Its now 10.00pm Sunday and still no updates.
