I have a beat up Dell 15" here that *several* people have tried to fix, so I am told. Symptoms: Not booting properly, would shut off after a minute when it did boot, fan ran on high all the time.
Opened the case to check things out, clean it, reseat everything, new CMOS batt, etc., and I am greeted with the strangest stuff I've ever seen on a CPU. Check out the pic.
Metallic gold in color. I did a google on it and found out there actually is gold thermal paste, so I guess that's what it is.
Question: Do my fellow techs feel that the previous guy applied enough?
It was even under the cpu, in the pins/holes. I removed the board, sprayed well with electronics cleaner, tapped on it to coax out any residual gunk. It was on there like glue, took a bit of doing to remove it all.
Reassembled, booted, has been running for over an hour now, so far so good. I just can't believe the work some guys do...
Thought sure it was done for when I saw all the paste under the CPU and in the socket holes.
Crossed my fingers and prayed on this one...
