JustInspired
- Kent, United Kingdom
A long time client of mine has asked me to service her dv6000 laptop (yes, I know!) and upgrade it to Windows 7 from Vista. She has the upgrade disc for Windows 7 that she bought previously but hasn't used yet.
This laptop gets VERY little use and it's in pristine condition. She has the docking station with speakers built in, extended life battery, in other words, quite a lot of money spent some years back.
Runs ok but is a bit slow and fan running continuously.
So, mistakenly I decided to strip it down, clean it etc before doing the upgrade.
This is something we have done MANY times before.
So I disassembled it, checked the heatsink fins - clear, unblocked.
Thermal compound on the CPU hard, needed replacing. Replaced with the good stuff (Arctic Silver) on this one as I know they run hot and have GPU issues.
Thermal pads replaced. We have all of the necessary sizes and thicknesses.
Install motherboard, RAM and display to test. Works fine. 'No operating system found' as expected.
Completed the re-assembly.
Tried to boot back into Windows. Get splash screen for HP, press F10 for BIOS etc, ESC for boot device etc. Then black screen, no cursor, completely blank but an illuminated black if you know what I mean. Happened each time. Hard drive indicator shows activity and I think it's booting to Windows.
What I tried:
External display. Same symptoms - BIOS screen then blank.
Boot from Acronis live CD. Shows the Acronis splash screen then blank when any higher res screen (UI) comes into play.
Removed the battery and charger and held down the power button (magic reset).
Disconnected the CMOS battery for several minutes.
F8 for selection menu - blank screen, no menu appears.
What I haven't tried yet:
Removing the hard drive.
Throwing it hard at the concrete floor!
Sigh. Yes, I know this is a dv6000 yada yada, GPU reballing, throwing it away etc etc.
How do I explain this to the client without looking like I caused it - which I did somehow!
Have I missed something...
Been doing this for a while and it isn't like I made a mistake that I can put my finger on...
What I tried:
