allanc
- Toronto, Ontario, Canada
Acer AX3470-EF10P.Allan, shoot us the model # of that Acer.
AMD Quad Core, 8 Gb of RAM, 2 Tb HD
Windows 7 Home Premium sp1 64-bit
At this point (3 am) I am exhausted.What kind of info are you seeing in the event log?
Last night at some point, everything seemed stable (after restoring the 'software' hive).OK, get a good night's rest and tomorrow let us know what the event viewer is saying. I'd expect to see something that would give us a lead here.
If nothing illuminating on the prior two steps, back up the registry hives and copy in all the hives from \Regback.
Check the serial number against updates available from Acer as well.
Are there any add-in cards, wireless NIC or the like?
Running on one RAM chip, then the other would be a good route too, if the prior steps don't yield any good info.
This PC may not have the most stellar power supply known to computing, so check your voltages in BIOS and with a multimeter.
Event from Windows Logs posted.OK, get a good night's rest and tomorrow let us know what the event viewer is saying. I'd expect to see something that would give us a lead here.
No, I haven't done either yet.This is starting to sound more and more like a RAM issue. Pull both sticks and put in ONE different stick that you know to be good.
Have you checked with ASUS for driver/bios updates?
Log Name: System
Source: Microsoft-Windows-Kernel-PnP
Date: 26/05/2013 12:04:34 PM
Event ID: 219
Task Category: (212)
Level: Warning
Keywords:
User: SYSTEM
Computer: Erin-Lily-PC
Description:
The driver \Driver\WUDFRd failed to load for the device WpdBusEnumRoot\UMB\2&37c186b&1&STORAGE#VOLUME#_??_ USBSTOR#DISK&VEN_GENERIC-&PROD_COMPACT_FLASH&REV_1.01#058F63616420&0#.
Log Name: System
Source: Microsoft-Windows-Wininit
Date: 26/05/2013 12:04:41 PM
Event ID: 11
Task Category: None
Level: Warning
Keywords:
User: SYSTEM
Description:
Custom dynamic link libraries are being loaded for every application. The system administrator should review the list of libraries to ensure they are related to trusted applications.
Log Name: Application
Source: Microsoft-Windows-WMI
Date: 26/05/2013 12:06:07 PM
Event ID: 10
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Description:
Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected.
A client brings in her computer saying that she "can't get any programs to run, the computer seems to be OK in safe mode but that mode is too limited".
An update (final I hope).OK, get a good night's rest and tomorrow let us know what the event viewer is saying. I'd expect to see something that would give us a lead here.
No, I ran out time due to other commitments and the client wanting the computer back.Well, you gave it a good go, but one can only spend so much time on that kind of stuff.
Did you ever get around to swapping out the RAM? Just curious.
Yes, I tried the repair install several times.I didn't read if you tried a repair install before you nuked it. That helps me about 2/5 times.
