The latest Fabs doing a transfer has a problem accessing remote registry hive, but only for Public items. Installed Software List is not created.
But the system32\config folder can be manually accessed and copied using File Explorer. This is for USB-connected drive from another system.
The last two times I've done a transfer, this problem has happened. Both times I closed Fabs then ran it again, deselecting all User items then Public allowed selection of Installed Software and Printers lists. Launching the transfer with just those Public items worked fine, giving me those reports. Weird.
Also still getting warnings about file size mismatch when the destination is 0 bytes when the file can't be copied. In this case it's processing My Documents and My Pictures folders that happen to be within OneDrive. I thought it was now smarter about copy failures?
In the above common situation with library folders residing in OneDrive, should the processing of My Documents and My Pictures be skipped and the files processed when transferring OneDrive contents?
