Have you used the windows system image repair (dism.exe) offline?
ell
Hi, looks like a nuke and pave on this win 10 machine, already tried system restore, chkdsk (keeps finding errors) sfc can't run but I want to try and use the dism.exe method, I am screwing something up here or maybe is just doesn't work from a offline command prompt (using windows recovery usb) any help?
I would focus here. Have you run full disk tests. Backup Data FIRST.
Yes ofcourse to both, drive is fine. I am basicly trying to learn how to use it to see if it actually works, have you used it?
You will need to image file from https://www.microsoft.com/en-us/software-download/techbench
Tech bench iso's include an install WIM which is needed to use DISM.
After you download it, just mount it using explorer and then use this command:
DISM /Online /Cleanup-Image /RestoreHealth /source:WIM:F:\Sources\Install.wim:1 /LimitAccess
This would be for the iso mounted as F drive, you may need to change it depending on what drive the iso mounts as
I was wondering why I couldn't find the wim file in the windows 10 iso. So do you know the command to mount it from a offline cmd? won't have explorer., unless maybe I just fire up a winpe disc. thanks
Just right click on the iso and select open with windows explorer and then select mount. Its will then show as a dvd with a drive letter.
Oh, I see what your saying, you mean a non-bootable system. Not sure how you would do it on a non-bootable system. If you can get it to boot, it will re-image windows 10 and it does a great job.
Can't boot to windows, so can't access explorer, been using windows recovery usb and the command prompt there.
yes thats my whole dilemma, msft says its supposed to work offline, but I can't make it work.
We keep the windows 10 images on a flash drive, if you plug in a flash drive, does the system recognize it when in command prompt mode? If the system gives the flash drive a drive letter when its plugged in, it should work.
I tried from a win10pe, fail I think it has to be used from within windows.
Mount wim file to directory (directory must be created first)
dism /Mount-Wim /WimFile:<Path>image.wim /MountDir:<mountDir>
And you have to commit the changes to the image when you are done
First create wim image
I got the image mounted no problem in win10pe, but the command prompt still gives the
Error 50:
DISM doesn’t support servicing Windows PE with /Online option.
The problem here is that Windows PE is the online version of Windows, so you do not want to use the online switch
