Sony Vaio SVE14122CXW.
If you check the picture you can see a separate wire that was attached to the video connector and im not sure what that supposed to do. Unfortunately was fragile and it came loose when i disconnected the video cable. The screen (LED) is broken but still lights up, well.. at least it did before that separate wire came loose. Now the screen is dim, has no back light anymore. I soldered that wire back but its still dim.
Before placing a an order on a new screen i wanted to know what is the purpose of that extra wire and if the wire is causing the screen to be dim ? Do i need to get new video cable as well ?
Any help/suggestions are much appreciated.
