pcpete
We just got a call from a client letting us no the lcd panel fell off the systemn after we did a repair several months ago. I have not seen the damage yet, but would not be surprised if some connectors on the logic board and/or panel are damaged. This sounds like an expensive mistake. Our procedure is to clean the old adhesive off and replace it with 3M 9474LE (300LE) double sided adhesive cut off of sheets.2.8mils and 3.4mils thick. We attach the thinner glue to the mac and attach the screen to the thicker glue. We then just apply pressure with a pinch all the way around. Should we be heating this to get it to stick better? Any other suggestions to prevent this from happening again?
