iMac with Fusion Drive circle slash on boot
timeshifter
USA
Approximately 3 year old 27" iMac. Circle slash on boot, which indicates problem with OS, etc.
Plan was to reinstall OS.
First tested by running built in diagnostics, no problems reported.
Second attempted Safe Mode boot, but it failed to circle slash.
Next I booted from High Sierra installer. Only volume showing during install was my external installer drive. Ran Disk Utility (GUI) and no internal drives appear.
Booted Sierra installer (not High Sierra). Same thing, except Disk Utility shows two internal drives. One 128GB SSD and one 4TB spinning disk. The SSD showed full, spinning disk empty.
Booted Internet Recovery which loaded an El Capitan installer. Again, can't see a volume to install to. Disk Utility from Terminal "diskutil list" shows what appears to mean that the Fusion Drive is broken.
At this point I'm planning to recreate the Fusion Drive and reinstall OS
https://support.apple.com/en-us/HT207584
Customer has a good Time Machine backup.
Is this a reasonable plan? Have I missed anything? Any other tips or tricks?
Then it sounds like the pairing was broken somehow. Had one of the drives been replaced or did this happen suddenly so to speak. Either way that's the only way to build a Fusion drive. This is a classic example why it's so important to have a bootable macOS drive with a live filesystem. Lets you boot from that and then operate on the patient.
Nothing changed, it happened all of the sudden. They had been out town, may have had power issues. But the system was working when they returned and they were using it. Not sure if they restarted the machine or whatever.
So a bootable macOS? I’ve never really done this. I do have multiple Mac OS bootable installers on my iODD. I know they were popular especially when all Macs had FireWire. So just install to an external USB drive?
I guess you can boot modern Macs from USB. But the thought of running an OS from USB makes me shudder.
Well, I can assure you I don't run around using that as a daily driver. LOL!!! But it works well enough for basic trouble shooting, diags, etc. I had a firewire drive but also sprung for a Thunderbolt a few years ago. Much more responsive and you can use it for regular macOS file transfers, etc. Most of them come with USB 3 which is pretty fast. You can get a USB 3 stick at a reasonable price as well.
Pull the hard drive and test it. Most of these systems came with a Seagate dm series drive that has a lot of failures.
That sounds like a good idea. I'm trying to think of ways to test the drive without pulling it. This is a big iMac where the screen is glued onto the frame. Would really like to avoid opening it up unless absolutely necessary.
You can boot from partedmagic and run their tests. On software. For a USB stick I just use basic OS X and if I want something specific I'll download it. On the TB drive it's identical to my daily driver except no email. This thread discusses what various people use. Pretty old so I'll see if I have any thing new I've been using.
You can :p
The copy I'm using that works on nearly every PC I've tried it on in the past, won't boot on this iMac. It gets to a point then the screen goes black and hangs. I even tried their "black screen fix" boot selection, but that took me to a text mode and didn't have the tests I needed. I'm going to download the latest version and try again.
Here's what I found when booting a live macOS disk and running a tool called smartctl
Techs-MBP:~ techboot$ diskutil list
/dev/disk0 (internal, physical):
#: TYPE NAME SIZE IDENTIFIER
0: *4.1 GB disk0
/dev/disk1 (internal, physical):
0: GUID_partition_scheme *121.3 GB disk1
1: EFI EFI 209.7 MB disk1s1
2: Apple_CoreStorage Macintosh HD 121.0 GB disk1s2
3: Apple_Boot Boot OS X 134.2 MB disk1s3
/dev/disk2 (external, physical):
0: GUID_partition_scheme *128.0 GB disk2
1: EFI EFI 209.7 MB disk2s1
2: Apple_HFS GoldSSD 127.2 GB disk2s2
3: Apple_Boot Recovery HD 650.0 MB disk2s3
Techs-MBP:sbin techboot$ sudo /usr/local/sbin/smartctl -a /dev/disk0
smartctl 6.6 2017-11-05 r4594 [Darwin 17.7.0 x86_64] (sf-6.6-1)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model: ST3000DM001
Serial Number: ZA502P59
LU WWN Device Id: 5 000c50 0871c3e46
Firmware Version: AQ03
User Capacity: 137,438,952,960 bytes [137 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s
Local Time is: Mon Sep 24 08:27:10 2018 EDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Read SMART Data failed: Undefined error: 0
=== START OF READ SMART DATA SECTION ===
SMART Status command failed: Undefined error: 0
SMART overall-health self-assessment test result: UNKNOWN!
SMART Status, Attributes and Thresholds cannot be read.
Read SMART Log Directory failed: Undefined error: 0
Read SMART Error Log failed: Undefined error: 0
Read SMART Self-test Log failed: Undefined error: 0
Selective Self-tests/Logging not supported
Techs-MBP:sbin techboot$ sudo /usr/local/sbin/smartctl -a /dev/disk1
Model Family: Apple SD/SM/TS...E/F/G SSDs
Device Model: APPLE SSD SM0128G
Serial Number: S2PBNYAG969431
LU WWN Device Id: 5 002538 900000000
Firmware Version: BXW5TA0Q
User Capacity: 121,332,826,112 bytes [121 GB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: Solid State Device
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS T13/1699-D revision 4c
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Sep 24 08:28:41 2018 EDT
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x53) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 10) minutes.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x001a 200 200 000 Old_age Always - 0
5 Reallocated_Sector_Ct 0x0033 100 100 000 Pre-fail Always - 0
9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 25236
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 153
169 Unknown_Apple_Attrib 0x0013 247 247 010 Pre-fail Always - 837562663392
173 Wear_Leveling_Count 0x0032 191 191 100 Old_age Always - 369386258600
174 Host_Reads_MiB 0x0022 099 099 000 Old_age Always - 7203307
175 Host_Writes_MiB 0x0022 099 099 000 Old_age Always - 5875067
192 Power-Off_Retract_Count 0x0012 099 099 000 Old_age Always - 59
194 Temperature_Celsius 0x0022 072 036 000 Old_age Always - 28 (Min/Max 18/64)
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
199 UDMA_CRC_Error_Count 0x001a 200 199 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
Warning! SMART Selective Self-Test Log Structure error: invalid SMART checksum.
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
255 0 65535 Read_scanning was never started
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Can boot Parted Magic now, just bought the 08-2018 version for $11. Previous was 03-2017 that had trouble.
Anyway, weird way that the spinning disk is reported with their tool. Shows the spinning disk, but capacity is shown as 137GB. As I type this I seem to recall that's a size that might be reported when OS / hardware has some limitation with a large drive. Anyway, here's what I see:
More signs pointing to spinning drive failure. Tried to recreate the Fusion Drive per the instructions at Apple I linked in the OP. Got an error stating "69760 unable to write to the last block of the device". Next I tried to manually setup each drive as an individual drive. Was able to erase the SSD and create a new Mac volume, went fine. But could not do the same for the spinning disk. Tried booted from a regular OS and from Recovery. Both times Disk Utility threw this error:
You can :p
Code:
   0:                                                   *4.1 GB     disk0
was never started.
been run.
command.
power-saving mode.
No Errors Logged
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
It's obvious /dev/disk0 is an issue
Device Model: ST3000DM001 = 3tb drive
User Capacity: 137,438,952,960 bytes [137 GB] = not even close
There was a recall for them by Apple - https://www.macrumors.com/2015/06/19/apple-27-imac-3tb-hdd-replacement-program/
By a small number, they mean, "All of them"
My customer's computer is a Late 2015 model. The Mac Rumors article states the recall is for "late 2012 27-inch iMacs sold between December 2012 and September 2013 may fail under certain conditions". Apple replaced the 1TB drive on my 2009 27-inch iMac under a similar program.
I did talk to Apple support and was told there was no recall for this system. I'll be at the Apple Store today for a different matter and will double-check and see what they'll charge to replace if not. Maybe I could point out the high number of failures of this series of drives?
