markcuk11
- manchester
I still think its the crucial 5,000 hours bug
Alright at this point if you've experienced or heard of this situation before then you should have the answer already.
The main things to keep in mind here is that it does crash like clock work (or so i've heard in the past). He already reinstalled windows.
There is only a few situations where something like this can happen so reliably. Unless im mistaken here and I don't think I am this only leaves 2 primary possibilities.
1. Something is influencing the power every 90 minutes...which i suppose is possible but not likely for a residential gamer.
2. Something is telling something to do something every 90 minutes and you already know reinstalling windows doesn't fix it.
Edit: hmm you know now that I think about it...was the issue every 90 minutes or every 60 minutes? I can't recall.
Hmmm , one thing I missed was seeing what process was invoked just before the bsod. I didn't try, how would I have found out which process was the culprit?
never said you didnt have it right mark =P
whats in the dump and whats in process monitor is the only things i know of.
Edit: Not that its relevant here as I don't believe anything would show for that particular issue.
Hate waiting for the answer![]()
Sorry =P I was curious about how others would approach the issue. Only reason I even knew about this was from reading a bunch of reviews when I was shopping for one.
If I didnt know the issue I know I would have determined quickly that it was very consistant. With the issue being that consistant and reliable like clockwork id have started googling the duration + the parts in the machine see if anything stood out. I'd have found the answer fairly quickly like that but not if I was one of the first purchasers and the issue wasnt known....i probably would have eventually cloned to the 500gb hard drive and tried it but who knows how long it would have taken me to resort to trying that.
The answer is:
The Crucial SSD 5000 hr firmware bug
Hey everyone.
For the past two weeks, I have had a machine in the shop that I just could not figure out.
Ok, but it took you TWO WEEKS to find this ?
I didn't think it was an issue because its a known problem and others found it in hours or just after reading your post ?![]()
ComputerRepairTech-- will you do the honors and describe the "Crucial SSD 5000 hr firmware bug" with references?
Biostar motherboard...double UGH.
I really like this format and the back and forth. It was a nice thread. Thank you!
