thecomputerguy
Doing a consult for a church and I know I'm going to need a least a couple of NanoBeams to connect buildings that are physically separated. Distance is 100-300 feet between buildings. I think I have a good understanding of what were going to need. I'll try to keep it as simple as possible to explain.
Main Building:
ISP -> Gateway -> 48P POE Switch -> 48V to 24V Converter -> NanoBeam 5AC Bridge
Satellite Building:
<- NanoBeam 5AC Bridge -> 48V to 24V Converter -> 8Port POE Switch Lite -> U6 Pro Access Point
Sound about right?
My question is ... is there a way to cut out the POE switch and use an injector somehow?
I know I need to still power the NanoBeam, but I'm reading online about people using injectors for their AP's along with the POE passthrough port which makes no sense to me because you still need to power the NanoBeam.
The POE passthrough only provides 24V while the U6 Pro AP and most of Ubiquiti AP's require active 48V POE.
I wish Ubiquiti offered a smaller switch since all I basically need to do is connect an AP.
@YeOldeStonecat
Main Building:
Satellite Building:
Sound about right?
@YeOldeStonecat
