garymce
- Glasgow, Scotland
Hi there, long time lurker and first time caller
A customer has recently shown me her computer which is having extreme problems booting up. The BIOS and POST both work fine, but it seems that anything beyond there, the computer will randomly shut down.
My first instict was faulty RAM, since I had that problem with my own PC a few years ago. I ran memtest86+ but it found no errors on either module. The PC has two 1GB DDR2 PC2-500 modules, I've also tried removing one, then the other and alternating between them but that hasn't worked either, so I'm assuming the RAM is fine unless it's a fault with the motherboard's connector.
My second check was removing the BIOS battery, starting the computer, then shutting it down and popping the battery back in to clear the CMOS but that didn't fix the shutdown issues either.
I tried running with just the bare minimum of PSU connections i.e. the 20pin/4pin and hard drive connectors, and again it failed to work. I removed the 300W PSU currently in the PC in case it was a power issue and replaced it with a spare 450W PSU I have, but again that didn't help.
It also doesn't seem to be a temperature issue as the heat of the processor seems to be remaining constant while in the BIOS monitor, although I have no way of checking while the PC is starting up beyond there but I'm assuming it's not the issue.
I've tried setting the BIOS to load both the fail-safe defaults and optimal defaults, neither of which have worked.
I also tried booting from a Ubuntu live disc to at least see if that was possible, but that also failed. The customer says that most days she can at least boot the PC to Windows Vista and can spend a random amount of time using her PC fine, then it'll randomly shut down and apparently after then it just keeps failing before even loading Vista. I haven't been able to reach Vista at all myself so I can't provide any information regarding that.
I'm absolutely stumped here. Any suggestions would be greatly appreciated!
Thanks
-Gary
Thanks
-Gary
