chrisappleby
- Nottingham, UK
Any ideas welcome on this problem computer brought in by a customer a couple of days ago.
PC switches itself off while booting into Windows.
It will run fine in BIOS all day long (even in graphical BIOS that comes with this mobo) or on a command line but as soon as it goes near a GUI it switches off.
Sometimes switches off immediately other times after 5-10 seconds in GUI)
PC was custom-built by UK supplier PCspecialist
Spec:
Mobo - ASUS P9X79 LE - socket 2011
CPU - Sandy Bridge i7 4820k running stock speed 3.7GHz. Stock cooler.
RAM - 32GB DDR3 HyperX Genesis (4x8GB)
PSU - New 450W PSU installed by customer prior to bringing to me
OS - Windows 7
This is what I've tried:
I initially suspected the PSU so put in a new 500W unit of my own - still switches off
Tried booting Linux live USB - still switches off
Tried a new passive cooled GPU - still switches off
Tried the new GPU in a different slot - still switches off
Removed all except 1 stick RAM - still switches off
Tried another stick of RAM - still switches off
Tried 1 stick in various slots - still switches off
Tried matching pair of RAM - still switches off
Removed CPU from socket, checked for bent pins, reapplied thermal paste, made sure CPU cooler was firmly attached - still switches off
So now I'm suspected a peripheral or short circuit to the case so removed mobo from case, removed all peripherals.
So now that leaves the mobo, 500W PSU, 16GB pair of RAM, power switch and USB stick with a tiny Linux distro - still switches off
Updated BIOS, reset BIOS to defaults, removed CMOS battery - still switches off
This mobo has various diagnostic LEDS. The one that lights up as the system switches off is the CPU one. However if you switch the PC off manually this LED still lights up so probably irrelevant.
Conclusions/questions :
- 500W PSU should be enough to power this set up. Could try a bigger PSU? Is it trying to draw more power as it goes into GUI?
- probably the motherboard (or a component on it). Replacement costs c.$300 so I'm reluctant to write it off without absolute proof.
- possibly the CPU. Replacement costs c.$200
- could try heating up various board components to see what gives
Spec:
OS - Windows 7
