It is on the file menu, you click on Multi User access and if never setup before it walks you through the wizard.
0. Backup your QB's company file (just in case)
"Step 0" is always "make a backup".
Before any work is performed or changes introduced, back up your client's data.
If you corrupt it or compromise it in any way, you have a safety net to fall back on.
You can setup users from any workstation with QB's (Company >> Set Up Users and Passwords >> Set Up Users) but you need to be logged in is an Admin in QB.
To be clear, these are QB's users, not workstation users.
1. Buy QB w/ multi-user licensing
2. Setup users in QB and define permissions (and user names and passwords)
3. Share the folder from the Host computer (and open appropriate F/W rules)
4. From your client's computer map that shared folder (Q for quickbooks usually helps) & set Q to open automatically on startup of the computer (not necessary, but it helps sometimes)
5. Install QB on your client's computer
6. On the host computer, open the company file in multi-user mode (c:\path\company.qbw)
7. On your client's computer, open the company file in multi-user mode (q:\company.qbw)
If you encounter problems with the sharing, use: https://intuitcorp.quickbase.com/db/bd9yykidd?a=dr&r=w&rl=cc2
Sometimes for simplicity, I actually map everyone (even the local user) to the mapped drive Q:\
One thing I'm unclear on: I think the guy only needs it for two systems, and I don't think they're networked. Probably no server. I'm not sure if I should be recommending two separate regular licenses, multiple multiuser licences orrrrrr the online version (which really, seems like it would avoid a lot of hassle?). @YeOldeStonecat
I would like to add to the list, make sure the clients stay on the same network!! One of the shares logged into the guest wifi account and she went all week messing with it before she called and I figured it out.What he said. The main thing to note is that for a second user to run QB at the same time requires a second licensed copy of Quickbooks.
You can use one license but the other user will have to log out when the second user wants to access it.
LOL, reminds me of one of our clients. One day we get a call that nobody can print to their one network printer. I went on site since they are not managed, and the printer is connected to the guest Wi-Fi network. When I asked who did this, of course nobody had any idea. Right, OK, so the printer just guessed that the guest Wi-Fi is one of your networks and it just happened to be able to guess the password correctly......sure, OK. Set it back to the hidden main network and all was good.I would like to add to the list, make sure the clients stay on the same network!! One of the shares logged into the guest wifi account and she went all week messing with it before she called and I figured it out.
I learned Intuit will no longer let you buy additional liscences for 2016...they force you to upgrade to 2018 to do it
The math still stinks, though (well, stinks for the end user, looks awesome to Intuit).
